I have searched on here and come to the conclusion that my AC clutch is bad. So I need to replace the whole compressor/clutch assembly. Is there a shorter belt that I can run until I get the new compressor?
I think you will run into routing problems if you try to bypass the A/C compressor without further modification....but good luck,maybe someone else will chime in.
you can use an bracket from a zj IIRC, it sells at napa for something like 15 bucks. or go to a pick and pull and just look a at few. we found bunches of them here close to home.
