Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old September 21st, 2018, 17:19
barillms's Avatar
barillms barillms is offline
5.3L LM7 swap into 88 Comanche build: Ebay headers
Hey guys, just wanted to share some info. I'm swapping a 5.3L into my 1988 Comanche buggy. And with the Novak mounts it makes life easy (but expensive)... To save some money you can find stainless headers on Ebay that will work. But it's often risky and hard to figure out which ones will fit.
These rub in one spot on the drivers side at the bottom of the firewall near the floor pan. A hammer will easily make clearance. The passenger side fits perfect. They come with gaskets and 02 sensor bungs welded into the down pipe stubs.
These were $136 made by AT Racing World USA. They are LS swap headers made for a Camero/Chevelle.
Ebay link:
https://rover.ebay.com/rover/0/0/0?m...30 1978136842
YouTube link:
https://youtu.be/WPYJozkjkRw
Old September 22nd, 2018, 20:18
barillms's Avatar
Re: 5.3L LM7 swap into 88 Comanche build: Ebay headers
These headers will require some heating & hammering to flatten out 2 spors to clear the steering shaft. And you must modify the steering intermediate shaft and go with a custom 2 piece 3/4" DD steering shaft with a 3/4" heim to brace it. Kinda like a hot rod set up. Will cost around $70.
Old September 23rd, 2018, 06:56
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
So now you're up to $206 in parts and some time to make these headers work, for ~$130 more the Novak ones drop in and should last longer than those eBay headers.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old September 25th, 2018, 13:59
1-tonxj 1-tonxj is offline
I still can't see the big power difference between a well built 4.6 stroker vs a budget 5.3 lm7 at 285/325 since the Golan stroker is 265/300 and for another $1500 in parts is pretty much identical power . I realize the Golan 4.6 is $4200-5200 depending on if you get it pre broke or not and Hesco heads are about $1500 , but it's a brand new motor not a junkyard 80+k mile unit and is bolt in item . I do not question the value of torque and horsepower of a v8 , but it just looks like on paper the lm7 without money into it you are not getting any more power than a stroker ... Feel free to correct that observation it's not one I can up with from real world comparison just simply got it from the power numbers the engines both claim.
Old September 26th, 2018, 05:45
indian's Avatar
indian indian is offline
barillms - that is great, that some cheap headers will work in XJ with little modification. I used (like others) stock F-Body (camaro 2001) headers without any modification
1-tonxj - I see your point. But for me it was mostly about the sound. There is no substitution for a healthy V8 sound. I changed the camshaft in my LM7 for a choppy idle one a now I would not change it for any 6 cylinder
(the cam has made another 30-40 HP, what HP tuners claims, so now I am at about 340 HP)
The price point is another thing, swapping stroker is much easier but not necessary cheaper.
https://www.youtube.com/watch?v=iDT92HlbUe0
Old September 26th, 2018, 07:11
sandfreestyle sandfreestyle is offline
Engine for engine the price is fairly close to the same. But with the V8 you have to get a trans and maybe t-case to match (unless you adapt yours) and that with the little odds and ends make the V8 more.
I think it comes down to your goals/desires. If you only want a max of 300hp then a stroker is the way to go, anything over that and the V8 is the most liable option. If you have an AW4 then you'd most likely be looking at a different trans to hold the power over 300hp anyways. Then it's down to apples and oranges.
Old September 26th, 2018, 07:19
I'm just in the process of deciding how much work and cash I wanna get into next year .
Rate This Thread:
Help Please... Ebay Headers? 87_Pioneer Modified Tech Discussion 13 April 23rd, 2012 16:40
Ebay headers RichP OEM Tech Discussion 21 March 10th, 2009 17:15
headers for sbc in a comanche?? CV95XJ Modified Tech Discussion 2 September 12th, 2008 11:15
ebay exhaust headers?? play_in_the_mud Modified Tech Discussion 3 June 29th, 2006 23:22
exhuast headers on ebay theschwarz1 OEM Tech Discussion 3 August 2nd, 2005 20:42
