Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old July 1st, 2018, 18:57
Tankerblade Tankerblade is offline
front 4 link Mounting
For those who have made a crossmember or some other way of doing the frame side mounts for a front 4 link system. mind posting them up and sharing your creations?
Have trouble coming up with a mounting system that I like with a 4 link system vs a radius/3 link system.
Old July 2nd, 2018, 08:55
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Re: front 4 link Mounting
I would go do a search on Pirate4x4. Lots of stuff like your looking for over there
Old July 2nd, 2018, 17:56
StinkyFab's Avatar
StinkyFab StinkyFab is offline
NAXJA Supporting Vendor
I know you seem to be wanting ideas for doing it yourself, but there's also the option of making it easy on yourself and just buying some brackets.
http://www.stinkyfab.com/sfr-jeep-xj...-arm-brackets/
Dallas Ashley
WWW.STINKYFAB.COM
Motor Mounts, Fabrication tools, and Custom stuff for your Jeep!
Old July 2nd, 2018, 22:33
Ah that's what I'm looking for. Appreciate it stinkyfab.
I haven't been able to find many mounts like yours, been out of the xj game too long and theres quite a few new players out.
In all honesty, this was the route I was hoping for, finding a set premade to just weld on.
Do your mounts fit with frame stiffeners already on?
Old July 5th, 2018, 23:30
Heavyopp Heavyopp is offline
Check out this thread -- https://www.naxja.org/forum/showthread.php?t=1148264
Should answer some of your questions -- I'll eventually be going this route too
From what I have read, yes the brackets will fit with stiffeners with just a little grinder love...
Old July 7th, 2018, 12:58
TRCM's Avatar
TRCM TRCM is online now
Some more food for thought if you need adjustability
https://www.naxja.org/forum/showthread.php?t=1143773
Old July 9th, 2018, 14:03
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
http://www.pirate4x4.com/forum/jeep-...l#post43960022
I find it comical you redirected the OP to pirate who sent him back here where he actually found what he needed.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Rate This Thread:
TNT Y link Mounting 2000bluexj Modified Tech Discussion 9 August 2nd, 2009 20:38
3 link question; long arm kit, aftermarket mounting points eroc37 Modified Tech Discussion 1 May 23rd, 2007 05:54
3 link mounting MercenaryXJ Modified Tech Discussion 4 April 12th, 2007 16:34
HP44 4 link mounting--Is the RE kit good-just under $400?? Any others??? Big Red Modified Tech Discussion 11 January 7th, 2005 17:08
Need a link for mounting tabs, FAST 4ward Modified Tech Discussion 7 September 25th, 2003 19:25
