Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old February 22nd, 2018, 09:26
burntkat burntkat is offline
NAXJA Member #1145
Bumper build- skin-on-frame method?
I am in need of a front bumper for my S10 SAS project. I want something reminiscent of an ARB, but don't have the ability to use CAD, a laser table, or a brake.
I thought about maybe doing a skin-on-frame sort of affair, building out the shape of the bumper with 1X1 square tubing. Then come back and skin it with 3/16 or 1/8" plate, depending on the section.
Obviously the winch tray will need to be heavy plate. I would prefer it was a seperate construction, personally, again a la ARB.
Has anyone seen a bumper built in this fashion? I think between the tubing and the frame it would likely be stronger- by a fair margin- than a mere plate assembly.
Old March 13th, 2018, 14:28
Rockwood Rockwood is offline
Re: Bumper build- skin-on-frame method?
Realistically, as long as you enclose the bumper "box" on the back in key spot (4 sides instead of 3), the frame would just be redundant.
Old March 13th, 2018, 19:55
bridgerx bridgerx is offline
Build it out of cardboard and duct tape 1st... then use the cardboard pieces for templates to cut the metal however you cut metal.
Old May 21st, 2018, 22:30
muddypunk muddypunk is offline
TOOL
This is how my bumper was built. Mostly 1/4" plate. Tons of grinding like days to round the top edge.
Sent from my Arse because my hands are full
Old May 22nd, 2018, 04:41
NAXJA Member #1145
That is pretty much exactly what I am wanting to build.
Old May 24th, 2018, 03:14
ftwelder's Avatar
ftwelder ftwelder is offline
I used string.
IMG_6780 by barnstormerbikes, on Flickr
IMG_6789 by barnstormerbikes, on Flickr
Old May 24th, 2018, 08:52
NAXJA Member #1145
I don't know how to weld to string.
Rate This Thread:
Too much bumper = frame cracks :( blistovmhz Modified Tech Discussion 24 November 23rd, 2014 10:59
Bumper and frame questions NewBreedCustom Colorado Chapter 20 August 16th, 2012 05:07
My bumper build: Re-sizing a 1971 ford F100 bumper for an MJ 88manche NorthWest Chapter 12 January 5th, 2009 17:42
My bumper build: Re-sizing a 1971 ford F100 bumper for an MJ 88manche Modified Tech Discussion 9 January 4th, 2009 01:32
