Old June 7th, 2012, 18:01
jeepkid03 jeepkid03 is offline
Fuel Check Valve
So lately my 2000 has been taking a little longer to start after sitting over night. It usually takes two quick tries to start it, or one long crank. When sitting for only a short bit it will fire up quickly like always. Plugs are good, and the issue only happens after it has been sitting a while. I'm pretty sure it is the common fuel check valve issue on 97+. I know this check valve is located in the tank, but is it part of the fuel pump? I checked RockAuto.com for just the check valve and didn't have much luck.
Thanks!
Old June 7th, 2012, 19:14
Sidewinder CC's Avatar
Sidewinder CC Sidewinder CC is offline
Re: Fuel Check Valve
It is part of the fuel pump module.
Old June 7th, 2012, 19:34
Thanks! Any recommendation on what brand to buy? This is something I'd like to do only once.
Old June 7th, 2012, 20:06
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Buy a Bosch. Never buy an Airtex.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old June 8th, 2012, 03:50
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
Better advice has never been printed!!
There are two check valves. One on the regulator and one on the fuel pump. As your problem could be either and because you have to drop the tank, I always recommend replacing the entire ASSEMBLY.
Old June 8th, 2012, 07:32
Wait so both check valves are in the tank? Or is there one on the fuel rail? Definitely buying a Bosch, thanks Tim!
Old June 8th, 2012, 07:59
Both check valves are INSIDE the tank and are part of the fuel pump "assembly". One check valve (primary) is on the regulator and the other is on the fuel pump itself.
Old June 8th, 2012, 11:43
heyhar's Avatar
heyhar heyhar is offline
And, please, do not add an external check valve. I was tempted a few years ago, and it was explained that from '96 on, there's no regulator or return on the rail, just a supply. Park with a hot engine, and the gas in the rail wants to expand, and the new check valve won't let it back into the tank. Not good!. I ran a can of BG44k through the tank, and maybe I'm dreaming, but it behaves fine again! And I can run 87 octane gas again, without the ping I was getting. No, I'm not a salesman for BG, but I always keep some on hand, and my JEEP and Subie OBW don't ping anymore!
Old June 9th, 2012, 06:18
Original_MudButt's Avatar
Original_MudButt Original_MudButt is offline
One check valve is inside the pump, inside tank. The other is on top of the pump, outside of the tank.
The one outside the tank sits atop the pump assembly. It's actually a filter, pressure regulator and check valve all in one.
You still have to drop the tank. But there is a simple strap that you pop off, then pry the FPR out. There is an o-ring that seals it also. A new o-ring should come with the FPR.
I bought mine from Morris 4X4 two years ago and have no problems with it.
All that being said, there are tests to be done to determine if it is the check valve or a leaky injector.
BMW fuel check valve DanDXJ OEM Tech Discussion 7 May 31st, 2011 19:17
Fuel Pump Check valve tragiccomic1972 OEM Tech Discussion 9 April 27th, 2011 13:36
Fuel pump check valve the_weirdo OEM Tech Discussion 1 February 23rd, 2011 20:38
Fuel check valve heyhar Tow Rigs and Trailers 10 November 15th, 2009 10:05
Fuel check valve OILBURNER OEM Tech Discussion 7 February 5th, 2006 00:03
