Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 35 votes, 4.89 average. Display Modes
  #4876
Old June 12th, 2018, 23:03
freerider15's Avatar
freerider15 freerider15 is offline
Re: What are you doing to your rig - the continuing saga
Been cranking back on the up and coming Sleeper DD XJ.
Mainly just getting it back to road worthy...then I'll get some axles built.
Currently:
- New Crown Braided SS lines Installed
- JKS Shock Stem Adapters and Bilstein 5150's installed
- Interior is *nearly done
- Working on getting my Boostwerks Hidden Winch Mount in
- Working on getting stereo, amp, and speakers all in before wrapping up the interior
- Derale Cooler and lots of AN fittings for Trans Cooler install
Looking to have it back on all fours and fully under it's own power (e.g. brakes) by the end of this coming weekend.
Then, unfortunately I'll need to figure out the source of my exhaust leak that sounds like its the exhaust manifold.
Once that's all kosher, slap the rest of the body on (fender, header panel, etc.) and it's in reality good to go for now
Really really really really jones'n to wheel the buggy. But, this has most of the parts sitting around, and I still don't have the truck transmission back anyhow yet (coming up on three ****ing months now...)
XJ Buggy On Tons
Old June 14th, 2018, 20:31
in4aride's Avatar
in4aride in4aride is offline
Got the sliders started on Ashs truck.
Grab a gear, let's go.
Old June 14th, 2018, 21:05
xj-grin xj-grin is offline
NAXJA Member #1096
Look nice, man. I have a set in the garage for the taco I haven’t found time to bolt up...
Old June 15th, 2018, 21:24
-xj4me- -xj4me- is offline
Painted this a few weekends ago, blew the transfer case on the way back from New Mexico and now it's getting a beefier tie rod and alignment tomorrow
Old June 17th, 2018, 21:06
in4aride's Avatar
Steel yard was closed so no further love for the taco sliders, did some more work on the trailer build and loaded up the taco to see how the extra room would pan out. I’m digging it so far.
Old June 18th, 2018, 20:27
in4aride's Avatar
Finally wrapped up the first go at sliders. Going to beat up on these and see if any changes are needed other than the few build designs I want to change.
Now to find some new leaf packs.
Old June 18th, 2018, 21:03
UnlimitedMatt's Avatar
UnlimitedMatt UnlimitedMatt is offline
Those sliders look good!
Weekend forcast: Camping with a chance of drinking...
Old June 18th, 2018, 21:07
in4aride's Avatar
Thanks brotha. Have some small design changes I want to implement. As well as go to DOM. Need to bang em up and see how they hold mounted like this.
Old June 19th, 2018, 11:58
time2getdirty's Avatar
time2getdirty time2getdirty is offline
my cats breath smells
As long as hey don’t bang your cab they should be good. Mine were 2x2.120 with the same for the legs. I did flat or c plate on the frame like you did and A 3”x1” triangle on the top side to support and hey we’re plenty strong.
Originally Posted by YELLAHEEP View Post
Probably gunna buy a JK.......
Old June 19th, 2018, 12:59
in4aride's Avatar
Yeah main is 2x2x3/16. Tube is 1.75-.120 legs are 2x3x3/16 and plating up top is 3.4x8x3/16. Mounts are 3/16. Think next run those will be update to 1/4. Front body mount tie in is 1/4
Old June 19th, 2018, 15:26
I’d say you are overkill already.
Old June 19th, 2018, 15:33
in4aride's Avatar
Rather over build than under, however some pieces like the top plate were just bacause it’s what I had on hand. Been debating if a small gusset on top of the legs at the frame mount would help with any flex in legs. A lot of options for these things are junk. And most of em are waaaay short. Everyone does 80”. I played modest at 86”.
Old June 19th, 2018, 17:08
trippled trippled is online now
Looks good. Is that just a piece of plate tieing the middle of the tube to the square slider part?
Old June 19th, 2018, 17:57
in4aride's Avatar
Yeah. Just some 3/8 I bent and tied in.
Old June 29th, 2018, 17:40
Originally Posted by freerider15 View Post
Slightly rotated pinion housing.
Once I *hopefully* get the pinion back in place, I'll strip the axle down except for the lower link mounts, and redo it all.
So. As I'm currently starting to build my axles, do you think just welding the tubes would've been sufficient to prevent that, or not? It seems most of the force would be between the housing and the upper link mount on the tube. I'm thinking of welding the tubes and adding maybe a small tube bridge but space is pretty tight on the driver side since it's a 90 Ford King pin.
Rate This Thread:
Death wobble, the continuing saga RockTracXJ Modified Tech Discussion 11 June 2nd, 2010 05:46
Continuing the downward spiral of 4x4 design Lawn Cher' Non-Tech / Off Topic 28 April 19th, 2010 11:49
The saga continues... sams88 User Support, Questions and Suggestions 0 September 1st, 2007 22:08
1990 AC saga keeps going... cherokee4fun OEM Tech Discussion 14 June 13th, 2007 21:02
'00 Headers, and the continuing lack of them KCNMDE Modified Tech Discussion 0 August 8th, 2004 14:21
