Old January 23rd, 2008, 18:22
BigRedMachine BigRedMachine is offline
ford 44 radius arms to long arms need ideas
I have a hp44 I converted the radius arms into long arms but where the radius arm would mount to a stock ford I fabed some control arms that angle up and mount before the crossmember.
the problem is they hang down so low I bang them off the rocks recently at gulches(a local ORV PARK) I broke one the welds held but the cast broke. I want to git rid of the cast and make some kind of steel wrap around the axle to long arms with some nive flex joint. The idea I have now is to un bolt the radius/long arms and take them to a machine shop and have them make some kind of steel c clamps that i can weld to and still use the rubber bushings.
I need suggestions and or pics.
Old January 23rd, 2008, 18:33
Wil Badger's Avatar
Wil Badger Wil Badger is offline
Re: ford 44 radius arms to long arms need ideas
Go to James Duff or Cage Offroad
Cages radius arm
you might be able to get cages front section then the arm can just bolt to that.
Old January 23rd, 2008, 18:45
thanks I'v seen thos but I'm not able to fork out 700+ dollars.
I like to keep things more custom.
ford radius arms ready to mud Modified Tech Discussion 12 December 24th, 2007 13:50
ford radius arms falcon1235 Modified Tech Discussion 6 October 30th, 2006 08:01
Ford Radius Arms XJ_ranger Modified Tech Discussion 7 February 26th, 2005 14:45
Those with radius arms NEED IDEAS Redcbr007 Modified Tech Discussion 8 October 11th, 2004 20:20
D44 with Ford radius arms shizza-my-nizza Modified Tech Discussion 58 May 7th, 2003 14:07
