Re-Gear with Revolution for Less Full Re-gear packages $349
RWKHausSupply
Looking to save money and get a Re-gear package that includes the highest quality aftermarket gears and master install kits. Well here it is.
CLICK HERE TO GO TO PACKAGE
GEAR PACKAGE INCLUDES:
Front and Rear Ring & Pinions
Front & Rear Master Installation Kits
RING & PINION SETS
Revolution Gear Re-Gear Packages are made from top quality 8620 Steel and are precision heat treated to OEM specifications, making for the best aftermarket gears available. All Revolution Ring and Pinion sets are backed by an industry leading 2 Year Warranty against defects. Revolution gears are also double, and in some cases triple lapped for flawless setup, smother running and longer life.
Ring & Pinion Gear Ratios Available:
4.10
4.56
4.88
5.13
MASTER INSTALL KITS
Master Install Kits Include:
new OEM quality Pinion & Carrier Bearings,
Pinion Seal,
Pinion Nut,
Crush Sleeve (where applies),
Ring Gear bolts (most applications)
Pinion & Carrier Shims
Gear marking compound and Loctite for the ring gear bolts.
REVOLUTION RING & PINION
Revolution offers a full line of Premium, Top Quality Ring and Pinion gear sets in all the popular ratios to accommodate most light trucks, Jeeps and rear-wheel drive passenger cars. Revolution ring and pinion sets are constructed to last longer, run quieter and setup easier than other aftermarket gears. We do this by concentrating on every detail in the manufacturing processes of our gears. From design, to final inspection Revolution’s attention to detail and precision guarantees that you’re getting the highest quality gear set available. Often times you need more pulling power out of your tow rig and the factory ratios are not low enough to give you the power you need. Other times you find that when you upgraded your under sized stock tires to something a little bigger and with more style you find that your speedometer is off and the power band seems to have slipped – it’s time to re-gear and reclaim your power. Revolution offers a full line of ratios for your 2 and 4 wheel drive trucks and SUVs. Revolution also offers a large number of ratios for your racing needs as well. Our performance gears are designed to handle higher horsepower and heavy loads. Whether you are correcting for larger tires, racing or just looking for more power, Revolution has the gear for you!
These kits are selling like hot cakes....
Get yours before the deal runs up...
