$375 - Chy 8.25, Dana 30, 35, 44 - Front & Rear Gear sets & Full Better Master kits
RWKHausSupply
RWK Haus Supply is back at it with a new better site, SAME Lowest pricing.
Get your parts Fast with 1-2 day delivery to most of the lower USA
GET YOUR LOWEST COST AND HIGHEST QUALITY RE-GEAR KIT HERE
2 - USA standard ring & pinion gear sets
USA Standard ring and pinion sets are the right choice to add confidence to your install. USA Standard Gear offers a full line of ring and pinion sets for a variety of common and hard to find applications.
2 - USA Standard Master Overhaul kits
Uses OE Quality Koyo bearings and races
Included are carrier bearings and races, pinion bearings and races, pinion seal, axle seals (front only), complete shim kit, ring gear bolts, pinion nut, oil baffles and slingers, thread locker, marking compound with brush and gasket.
These are some of the highest quality gear sets you can buy and the most complete full master install kits available. If you wanted to replace all shims and items in your differential (except the carrier) and you buy a different branded master kit, you likely will not have all the shims, slingers and baffles needed to complete your install.
Really want to save $$ while getting a stronger and better setup?
Add a 4340 Chromoly front axle kit for only $410 to your door.
Or a Spartan front locker at $249 or rear at $255!
Warranty: 1 year warranty against Manufacturer defects​
Re: $375 - Chy 8.25, Dana 30, 35, 44 - Front & Rear Gear sets & Full Better Master ki
Dana 50 and sterling 10.5?
Sent from my 0PJA2 using Tapatalk
What year? and what ratio?
5.13 the axles are out of a 2001 f350
Tried to PM you a quote but your box is full.
If only they made a 4.27 ratio for the reverse rotation D30....
EDIT: Nice deal on the complete front, and rear XJ package!
And on that note, I guess I am going with 4.56. I'll be talking to you soon!
Still in stock and still the same great deal!
