RWKHausSupply
- yorba linda, Cali
For the month of August.
Buy a Currie Front AntiRock Sway Bar Kit and get a
FREE CURRIE MOTOR MOUNT KIT
GO HERE TO ORDER
CE-9900XJF - XJ/MJ Antirock® Front Sway Bar Kit
This is the bolt on front Antirock® sway bar kit for the '87-'01 Jeep XJ Cherokee and '86-'92 Jeep Comanche pick ups. Kit includes semi-gloss black powdercoated billet aluminum brackets, splined torsion style sway bar, arms, adjustable length heim jointed links, and all mounting hardware.
The CE-9900XJF Antirock® sway bar kit directly replaces the stock Jeep XJ (Cherokee) and MJ (Comanche p/u) front sway bar. The object of the
Antirock® sway bar system is to balance the front and rear suspension when the vehicle is off road resulting in better, more consistent traction.
The sway bar is designed to be left connected while on and off road. On the road, the vehicle will have more body roll than stock. Adjustable
sway bar links allow for minor preload adjustments. The sway bar itself is of a torsion bar style design and is made out of 4340 alloy steel. This
matches the quality that is commonly used in off road racing today.
AND BY EMAILING OR CALLING FOR THIS DEAL YOU GET CURRIE MOTOR MOUNTS FOR FREE
CE-9201 - TJ/LJ/YJ/XJ/MJ Heavy Duty Motor Mounts
Currie's heavy duty motor mounts fit all years of Jeep YJ, TJ, LJ, XJ, and MJ vehicles with the 4.0L 6 cylinder engine. These specially designed motor mounts directly replace the stock OEM part. Features include super heavy duty construction with large diameter urethane bushings to absorb vibration. All mounting hardware is included. Semi-gloss black powder coat finish.
GO HERE TO ORDER
