Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > WinterFest 2010
WinterFest 2010 Planning and discussion for MWC WinterFest 2010. March 5-7 2010 at Badlands ORP, Attica, IN
  #61
Old March 18th, 2010, 09:44
REWSTER's Avatar
REWSTER REWSTER is offline
BACON!
Re: Carnages!!
my plan was to replace them with 3/16 2x6, but i figured i could let them get beat up until i get around to it since i will be taking them out anyway,but i would be a little upset if i dropped down and screwed up my door
  #62
Old March 18th, 2010, 10:29
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
Re: Carnages!!
Beating on your rockers affects the rest of the door opening. If you trash them, you'll have headaches later when you think it'll be easy to just replace them.
  #63
Old March 18th, 2010, 12:07
XJ&CHZ4ME's Avatar
XJ&CHZ4ME XJ&CHZ4ME is offline
Re: Carnages!!
Josh is 100% right. I have the 2x6 3/16" rockers now, but I actually came down on my old sliders so hard it pushed them up into the rusty rockers and it was so tight that my door drug on the bottom when trying to open them. Some creative work w/ a welder, u-bolts, a winch, a grinder, lots of flapper and cut off wheels and a BFH and countless hours got everything back in line so I could weld in the current set up. Way more work then I really wanted to put into it...
  #64
Old March 18th, 2010, 12:10
GoSlowGetStuck's Avatar
GoSlowGetStuck GoSlowGetStuck is offline
Re: Carnages!!
My Grand had the plastic covers over the rocker panels, and after the last time out they still looked fine. I pulled them off anyway and the metal rocker underneath is pretty banged up. Pinch seam is still in decent shape though.
I need to take care of it before it gets worse. Sounds like replacing the rocker altogether is much preferred to bolting a slider underneath it?
Brad - Midwest Chapter Treasurer
97 XJ build thread
  #65
Old March 18th, 2010, 12:19
XJosh95 XJosh95 is offline
Re: Carnages!!
I guess I should anticipate some work since my rockers are trashed.
  #66
Old March 20th, 2010, 08:57
FlexdXJ's Avatar
FlexdXJ FlexdXJ is offline
Re: Carnages!!
Yeah thats why i got my sliders on before WF, My rockers are perfect so I wanted to keep them that way.
97 XJ, OME, JCR, HDOR "HObrid" cage blah blah blah... DD/trail rig, '66 M416 expo/truckbed trailer, 02 Subaru WRX wagon
[QUOTE=*89Laredo*;246072645]
The human skull makes quite a loud noise when it hits a metal chair.
[/QUOTE]
  #67
Old March 20th, 2010, 09:06
87manche's Avatar
87manche 87manche is offline
Re: Carnages!!
if they've already been dented you'll never get a prefabbed slider to fit right, not without a crap ton of work anyway.
Besides, why lose the clearance? Just cut them out. It's not like your ZJ is in perfect shape.
  #68
Old March 20th, 2010, 09:26
seanR's Avatar
seanR seanR is offline
Want to puff on my pipe?
Re: Carnages!!
Originally Posted by 87manche View Post
...a crap ton...
Just what is "a crap ton"?
http:/http://www.urbandictionary.com/define.php?term=Crapton/
I see, it all makes scene now
My pen is huge
Originally Posted by BRIANHO13 View Post
[RTETTY DTR I JSVR NRVER BERNN THING DRRND.
  #69
Old March 22nd, 2010, 06:59
Re: Carnages!!
Yep, that's what's going to happen. Just have to harass the right person with fab skillz who can hook me up. Because I sure can't do it myself.
97 XJ build thread
Rate This Thread:
