OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
#61
![]() Quote:
Hey Greg, Thx 4 the quick reply with regards to which end is which after you cut the tan and lite green wires. Will probably ck them this weekend. But here is another question... according to PHRED who also used the DUAL SOCKETS said he swapped the red and yellow wires to get it to work. Could that be my prob if my earlier question is corrected or ok to begin with? I'm not in the garage now so I'm not even sure which blade went to which wire. If memory serves I think it was Yellow went to 87 and Red went to 85? Do you think if I just swap the connections (put 12V feed to Red and 87 to Ground instead of swapping out the wires on the socket) it will work or will it cause a 12V Short/Fire? btw - My 10 Ga (30A Fused) Power wire is direct to positive battery terminal thru firewall and then split into 14 Ga to Yellow (87) on both Dual Sockets. The 14 ga is around 2 feet long on driver's side and 4 feet long on pass side. Do you think the 14 ga wire would present any probs in delivering enough current to the locks? Hope I'm making sense. Thx, Phil |
#62
Re: Greg Smith Writeups
Yes. Using a Bosch type relay you would wire it as follows; #30 B+ #85 Ground #86 Purple wire going to fuse panel (cut purple wire) #87 Purple wire going to master switch (cut purple wire) |
#63
Re: Greg Smith Power door locks writeup
for those who when to the battery lug....where did you go through the firewall with the wire?
thanks |
#64
Hey Greg Smith or Anyone,
Stupid Question, How many relays are used for this project (two or four)? I wired BOTH SIDES using FOUR Relays; the DRIVER'S SIDE exactly like the passenger side in the Schematic Diagram and it doesn't work. Was I supposed to do the Driver's Side too or no? ChipsXJ - on my '88, below the Driver's side hood hinge on the firewall is a large grommet. Pull that out and you'll have enough space for any size wire to pass thru. Thx, Phil |
#66
http://southeasternxj.com/tech/tech_locks.htm Good Luck. Greg |
#68
Mr. Jay welch:
I sent you a Email. thank's Rikck... |
#69
![]() Quote:
EUREKA, IT'S ALIVE!!! MUHHAAAAA!!! LOL I removed the Relays from the Driver's Side and put it back the way it was. Then I carefully checked the Pass Side wiring was ok but discovered that I had 30 and 86 reversed. Once I changed it, all of the locks were slamming open/shut (including the Trunk)! First time it's done this since I bought her TEN YEARS AGO!!! Now, I won't hurt my back anymore turning around to open the lever letting someone in. Greg, U R DA MAN! btw - While I was at it, I added a switch to the antenna motor so I can shut off the antenna at will. Really handy since I rarely listen to the radio; mostly MP3's and CD's. Thx, Phil |
#70
![]() Quote:
#71
The new door lock solenoids you installed will also help reduce the amp draw needed to run the system but doing so never fixed the inherent problem for me. Even after replacing solenoids I still had to come up with this relay fix. Very happy you got it working. It is amazing how great it is to have them working after so many yrs of being annoyed by the malfunction.
#72
![]() Quote:
I was thinking about doing this but on that site it says to splice into the PURPLE Wire with a WHITE STRIPE you mentioned just plain PURPLE. Which is it? I'm confused. btw - Someone at that thread said they got smoking wires when they ran the 10 ga wire to the purple or purple/white wire (don't recall which). Thx, Phil |
#73
According to my 89 FSM the power wire from the 30 ampt circuit breaker to the master pwr window switch in drivers door is purple (they call it vt-violet but it looks purple). It then goes through a connector in the left hand kick panel and then into the drivers door and to the switch. Beware FSM also says there is another purple wire going from that switch back to that connector but as it comes out of that connector it becomes a purple wire w. a white stripe. That wire is not the pwr going to the switch but rather the constant pwr out of the switch that goes to all the other pwr window switchs to allow the operation of those windows at those door locations. So you have to be careful about which purple wire you hook into by tracing the wire and make sure it is not the one that becomes the one w. the white stripe. Greg |
#74
This worked exactly as described. That is once I re-read it. I reversed 86 and 30 and it did not work. Then I re-read and corrected MY ERROR then it worked perfectly. Thanks Greg! |
#75
Glad it worked for you. Enjoy!!!
Thread Tools | |
Display Modes | |
Thank you Greg Smith... | jmeti000 | OEM Tech Discussion | 3 | November 23rd, 2014 15:53 |
Greg Smith Power Door lock writeup | XJEEPER | Modified Tech Discussion | 8 | January 12th, 2013 18:16 |
Power Door Locks - FIX Rear Hatch & Driver Door | 5bucks | OEM Tech Discussion | 3 | October 14th, 2010 23:58 |
Greg Smith power door lock questions??? | xjtrailrider | OEM Tech Discussion | 15 | December 19th, 2009 19:52 |
Greg Smith | kellen | OEM Tech Discussion | 3 | September 13th, 2004 06:17 |
