Fuel Pump Check valve
IIRC once the fuel line leaves the gastank and runs along the driverside uniframe rail it is 5/16" or possibly the metric equivalent, but I would climb underneath the vehicle to make sure....
There's a place that sells just the filter/check valve that is part of the fuel pump. That is what I plan to do with mine, I think it was under $50.
Rock auto has them, but they are pricey, listed under 1997 JEEP CHEROKEE COUNTRY 4.0L 242cid L6 MFI (S) OHV : Fuel/Air : Fuel Injection Pressure Regulator.
Then Morris 4x4 has them also.
The only problem I see with this is that you probably need to remove the pump to do this. Might as well replace the pump while your hands are dirty.
dang it--- didn't want to hear that, but thanks for saving my life!!!
Might as weel get a whole pump, since a stroker is in the works.... can anyone recommend a good pump that will feed a gorilla stroker?
