rockethound
- Garland, Tx
I am pretty sure that my fan clutch is out. But i would like to know how it works before i replace it. I'm thinking what happens is that when the jeep gets to a certain temp, some kind of metal expands inside the clutch and this causes it to engage the fan. My engine temp goes up to 239 degrees when the A/C is running and when i turn off the engine and try and spin the mechanical fan it turns pretty freely. I would think that if my above theory is correct then it wouldn't turn at all.
Symptoms:
It overheats when the A/C is on.
It overheats at idle.
It overheats if the A/C is off and i go faster than 65. (the temp will slowly rise if i go any faster)
I've already invested close to $700 trying to track this down. I found out that it was missing the electric fan when i was 250 miles from home and the only place to stop was a Jeep dealership. $375 later i had a new stock elec fan but it still overheated. I have recently also replaced the upper and lower hoses, t-stat, and had it flushed but it still overheats.
Am I correct in thinking that it's the fan clutch?
It's a 91 4.0 HO
Symptoms:
It's a 91 4.0 HO
