Ignition Switch Removal
BIGSLVRXJ
Des Moines, Iowa
Ignition Lock Cylinder Removal
Can someone tell me how to remove the ignition lock cylinder on my 1990? Do I have to tear apart my entire steering column or can I just take the surrounding shrouds off? Let me know and thanks in advance.
Collin
remove the steering wheel, then you need a tool that can press the spring loaded lock plate and remove the retainer so the lock plate can be removed.then loosen the turn signal switch and you will see the screw that holds the lock cylinder in place. remove that and the lock cyl. will slide out.
Fantastic Ill be needing that.
