fordtech
- Amherst NY
I thought I had read somewhere that the RE add-a-leafs give quite a bit of lift (?).
Im looking into their budget boost kit, and maybe using zj springs up front to get around 3 inches. Depending on the rear height, I may use tappered blocks or longer shackles if needed. I think I could do this for 250-270 easily. Hopefully Ill be ok without a sye for now. I hope to use 30's, maybe 31's. I have the steel wheels now, but hope to get some jeep alloys. I figure its a good start and i can build from there.
I may still try to swing a 3.5 super-ride, but then ill need sye, and have no tire money.....
any other recommendations for a budget build (700-800)? I only wheel 1 or 2 times a year now. I would also like a fair priced aggressive AT.
Thanks!!!
Thanks!!!
