OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
QUICK STEP BY STEP ON FUEL PUMP REPLACEMENT
HEY GUYS MY FUEL PUMP WENT OUT AND I JUST NEED A QUICK STEP BY STEP ON HOW TO REPLACE IT PLEASE :-)
I WILL HAVE NO ACCESS TO A SERVICE MANUEL AND LIMITED ACCESS TO A COMPUTER OR ELSE I WOULD SEARCH MORE AS SOME OF YOU MIGHT SUGGEST I DO. I WOULD GREATLY APRECIATE ANYONES HELP 1993 JEEP CHEROKEE SPORT AUTOMATIC 4WD |
#2
Re: QUICK STEP BY STEP ON FUEL PUMP REPLACEMENT
All caps?
#3
Step one is to turn off caps lock. I can't help you with the steps after that.
#4
disconnect the battery (sparks + gas dont mix)
pull off the wiring harness and fuel lines use a brass punch to remove the lockring pull the pump and all that mess out put the new pump in and replace the seal put the lockring on and hook the lines and wiring back up |
#5
No service manual and won't go buy a book...
One step: Go to a local shop and have them replace it for you. If you insist on doing it yourself... Before doing any of the steps listed in a previous post, get the truck as low on gas as possible. If you pop the sender and there's gas there, you will wish there wasn't. The brass drift step is no joke. If you use a steel one, and it sparks, you may have a bad day. Remember that bulk fuel ( the wet stuff ) is less dangerous than the vapors. Vapors + Spark is bad. Vapors + Spark + Confined space is very bad. |
#6
WHY ARE PEOPLE SO ANAL ABOUT THE CAPS LOCK?
#7
ThAnKs GuYs i wEnT AhEaD aNd dId It aNd GoT'Er DoNe....tHaNkS fOr tHe iNpUt
#9
Thread Tools | |
Display Modes | |
My step son is looking for an MJ | Loose_Nuts_Enterprises | SoCal Chapter | 20 | May 24th, 2006 19:37 |
Need fuel pump replacement help QUICK "please" | cjben | OEM Tech Discussion | 3 | April 10th, 2005 21:21 |
What should my next step be? | jeep4x4nut | Modified Tech Discussion | 0 | December 21st, 2004 17:00 |
Need step by step for replacing radiator. | Dexter | OEM Tech Discussion | 11 | December 7th, 2003 07:33 |
First Step | TriZZle904 | Jeep Street and Performance | 4 | August 18th, 2003 07:35 |
