Old June 2nd, 2010, 11:26
outlander's Avatar
outlander outlander is offline
step by step gearing writeup or link?
I'm close to diving in and regearing my 8.25 and d30 myself and don't wanna screw it up.I'm looking for a good writeup or guide to study so I don't make any avoidable mistakes.
What do you have?
Anything will be much appreciated......
Oh and we need something like this in the faq section would be the shit to have it in pdf.....
Old June 2nd, 2010, 11:36
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Re: step by step gearing writeup or link?
IIRC, the Factory Service Manual has a really good section on gear setup. And it's just a really good set of documentation, period.
And no, we will not be posting the section from the FSM, or links to it, due to copyright infringement.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
http://www.jeepforum.com/forum/f19/r...xj-d44-992471/
Old June 2nd, 2010, 11:46
RCP Phx RCP Phx is offline
The biggest issue would be having all the correct tools,after that a lot of patience!
Old June 2nd, 2010, 11:58
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
Originally Posted by 1990JEEPXJ View Post
That's a pretty good write up. It is essential to have the right tools to do gears. It is also essential to have patience when setting it up. You may have to take it all apart and put it back together again a number of times but time spent getting it right now will ensure a long happy life for your gears.
Old June 3rd, 2010, 02:18
grizz78's Avatar
grizz78 grizz78 is offline
BillaVista did a great job with these
For the 14 bolt
http://www.pirate4x4.com/tech/billav...4b_Gear_Setup/
Dana style axles
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
The real pain with DIY regearing is the initial investment in tools. Dial type in/lb torque wrench, a shop press, among others.
Does anyone else have experience regearing using some other tools or methods that could cut that cost down??
Old June 3rd, 2010, 06:33
old_man's Avatar
old_man old_man is offline
I use a beam type torque wrench for preload. It cost me $28. I also made my own setup bearings. I honed the insides with a brake hone.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old June 3rd, 2010, 07:22
trd_xj42 trd_xj42 is offline
I used this one on here.
http://www.naxja.org/forum/showthread.php?t=90711
You have an 8.25 so yours will be slightly different. You'll need to buy or make this tool.
http://eastcoastgearsupply.com/i-129...ster-tool.html
Old June 3rd, 2010, 09:43
outlander's Avatar
Thanks!!!
You guys are the $h!t....
Since we're on the subject:What brand does everyone prefer?I saw a link for front and rear gears and instal kits made by motive gear for $500....deal?
Thanks again guys...Ill post up for a pattern check when I'm done...
Old June 3rd, 2010, 22:21
jeeperjohn's Avatar
Originally Posted by outlander View Post
Thanks!!!
I suggestbyou check with www.rwkhausesupply.com he is supporter and he recommends Nitro gears.
Old June 3rd, 2010, 22:41
outlander's Avatar
Never heard of those...
Step by step write up strokers Robahr24 Jeep Street and Performance 5 December 11th, 2008 10:48
Motor Mount Replacement - Step by Step kd5dwy OEM Tech Discussion 15 February 9th, 2007 09:22
Budget Long Arm step by step build COMING SOON! barillms Modified Tech Discussion 12 January 31st, 2007 20:08
QUICK STEP BY STEP ON FUEL PUMP REPLACEMENT afjeep2082 OEM Tech Discussion 8 July 10th, 2006 15:43
Need step by step for replacing radiator. Dexter OEM Tech Discussion 11 December 7th, 2003 06:33
