Nasal buzz with RPMs, 97 XJ
illidurit
CA
My 97 XJ Country (4x4 auto) developed a buzzy frontend sound about a week ago.
When it happens:
-When I press the gas pedal
-In drive or in park
-Even in neutral
-Hot or cold
Sound quality:
-Buzzy and nasal and sorta whiny
-Within the register of a typical man's voice (I can kinda plug my nose and make a nyeeeehhhhhh sound and it's pretty close)
-The pitch of the sound tracks the RPMs exactly, including rising with acceleration, falling with deceleration, and jumping with shifts
Where:
-It's coming from the engine bay
-Seems like it's near the block
So what's going on??
Just to clarify, can you hear it when it is just idling? If so, it could be your power steering pump, I've seen where they start whining if moisture gets inside them. I tried to comprehend the sound your explaining and that's what I think of. Another thing it could be, but probably isn't, is your alternator, sometimes when they get wet they can make some horrific sounds, but that goes away after 10-15 seconds.
Remove the serpentine belt and see if that eliminates the noise. If so, check everything the belt spins for roughness.
The suggested mechanic's stethoscope is the right tool for finding failing bearings and other internal parts going bad..
It does sound like a power steering pump.
