What's left to do....
043500
Ocala, FL USA
for next year? LOL
New passenger rear door window, uncrush roof so passenger front door is useable, roll cage, rocker guards, pop-up camper (maybe), replace windshield (unless it doesn't fall out), get broken oil dipstick out of dipstick tube, re-do rear brakes, replace rear axle seals, some sort of real spare tire mount.
SYE & double cardan rear shaft, u-bolt pinion yoke.
Traction aids & alloy shafts fore & aft; 4.56:1 gears, HD diff covers.
New tires before then
5Kfab front bumper, M8000, synth winch line, Foreward Momentum billet fairlead
Repack or replace passenger seat to keep my co-pilot happy.
More red interior lights.
Build front 44 so I can stop replacing axle shafts
New rear DS
BOR rear leafs
Raise rear shock mounts
Interior cage
Cut rear QTR panels and install new rear bumper
Get a CB that works
Forage for trail spares
AX-15 sawp, 203/205 t-cases, keep the shit running till then!
Humm I need to get a jeep and put my lift on it..a locker and some rocker protection and then maybe some gears....:)
Fix minor leaks, line floor pans, vinyl carpet, replace crossmember, hack'n'tap/full SYE and front DS, 4:56s, 8.8/29 spline rear (if I don't already have one - not sure yet), synthetic line for the M8000... a lot is still undecided, but I definitely konw the next upgrade will be my gears.
yellowxj said:
tighten bolts, better rear leaves, winch...install 2" trailer ball in seat
Make that a 3" ball , in case you want to try and top that ballet move you made this go round:)
LMFAO!
