Kevin
- Richmond, VA
I've seen a couple of post about this magical liquid and figured what the heck, lets give it a try. The bottle says you can dump it in the gas tank, no problem, in the crankcase oil, no problem and then down into the throttle body. Thats where I have the problem. I just wanted to make sure that all I would need to do is disconnect the air hose connection and pour the sea foam in right there? Seems easy enough, but I wanted to make sure. Anyobe have experience with this stuff?
