Jeff in VA
<---respect
- Richmond, VA
Swapped trannies this weekend on my MJ (2WD to 4WD AX5) and ran into a small problem. On the 2WD trans, there are 2 sensor/switches on the pass side that run into a single 4 pin connector, but the 4WD trans only has one sensor (the one more towards the front if looking down on it from above). The other sensor that wasn't there threads into the side and it's a ball/plunger type device. There's a boss cast into the side of the trans where it would go, but it's sealed and not threaded. Would that extra sensor be for the goofy upshift light on the dash that my truck has? I'm assuming that the other switch is for the backup light circuit, because both trans have it. Maybe the donor truck I got the trans from didn't have the dash light??
I checked wiring diagrams in both Chilton's and Haynes, but that was worthless....can anyone confirm that sensor function?
Thanks,
Jeff
Thanks,
Jeff
