EvilCherokee
- Milton, NH
A friend of mine was at the junkyard today, and found a dash clock out of a Cherokee. I went to install it, and I cannot locate a plug for it. I took out my instrument panel, and looked with my flashlight, and I don't see any harness that will hook up. Anybody know if the vehicle wasn't ordered with it, the wiring isn't there either? Also my lights for the switches(defrost, tranny mode, etc) are not working. I checked the bulbs, and they are fine. All my other dashlights are fine as well. I figured those switches would be on the same fuse as the dash lights, but if there is a blown fuse, I don't know what one it is. The owners manual lists the bulb type under "Rocker Switch Lamp", but when you look under the section that describes where in the panel that particular fuse is located, there is no listing for rocker switch lamp. I'm baffled.
