deepcdiver
- Normal, Illinois
My 2001 XJ has a 3" lift and 31's. I installed a transfer case lowering kit to reduce the vibes, and it worked great. I purchased the Skyjacker kit, which includes a shifter bracket (small square plate with holes). Instructions inclosed with the kit simply stated to refer to the instructions packed with the bracket to determine mounting requirements. I was told that the plate is only required for manual transmitions, and no adjustments were needed for my automatic tranny. I am getting a bit of tranny noise every once in a while. If you look at the linkage underneath, the connecting rod from the 4X4 shifter knob to the transfer case, it now goes at a downward angle. Does anyone know if the noise I am hearing might be associated with the lowering kit, and furthermore, the lack of the bracket? Or, is there any modifications that I should make to the transfer case lingage?
