Anyone have any thoughts on the new Warn winch?
sportsguy
MAGNUM 9K Self-Recovery Winch
http://www.gowarn.com/magnum-9k-self-recovery-winch.asp
The new MAGNUM 9K 9000lb Winch. A private Label winch manufactured by WARN Industries. This great entry level winch includes 100' of 5/16 wire rope, hook, Roller Fairlead, 12' Lead Remote Control Switch, 72" Battery Leads and Mounting Bolts. Compares to the WARN XD9000 and the Ramsey REP 9000 for a lot less money. Limited Lifetime Factory Warranty.
MAGNUM 9K Winch Specifications
Part Number: 900560
Rated Line Pull: 8820 lbs. single-line
Motor: 4.3 hp, Series Wound
Geartrain: 3-Stage Planetary
Remote Control: Remote switch, 12' lead
Gear Ratio: 216:1
Clutch (freespooling): Sliding Ring Gear
Brake: Internal Automatic
Weight: 77 lbs.
Wire Rope: 100', 5/16" diameter
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Winch Dimensions: 20.89" L. x 6.3" D. x 6.4" H.
Mounting Bolt Pattern: 10.0" x 4.5" On Center
Battery Leads: 2 gauge, 72"
Finish: Argent Gray Powder Coat
MAGNUM 9K 12V DC PERFORMANCE SPECIFICATIONS
Line Pull
Lbs. Line Speed
FT./min Motor
Current
0 27.7 126 amps
1000 14.8 237 amps
2000 10.3 344 amps
3000 7.6 452 amps
4000 5.9 559 amps
Above performance specs are based on first layer of drum
$564.95 USD
the first place has free shipping
interested to see if anyone has some "inside" info on this. I love getting off name stuff for less.
We've been running one on my friends rig for about 9 months now and it's been working great. We've used it around 15-20 times, on other people of course, and have had no problems.
Chris
