multmigs
- Valley Forge, pa
I pulled these factory disk brakes from a 1996 ZJ, they bolt right onto any D35 or C 8.25 rear axle with drums. This is the factory caliper brackets, and calipers which I had blasted and powdercoated. I have some not so great looking backing plates and some of the required hardware, you will need to buy pads, rotors, and the emergency brake parts if you choose to use them. $200 for all, I'd estimate you have another $150 of stuff to buy to complete it and I can provide a list of part numbers if you need it.
