brtb
- Orlando, FL
Ok, so I'm trying to put in a CB. Got it wired in fine, when the ignition's in ACC i can get signal, transmit to other people, the thing works fine. Whenever the key's turned to ON, much less when it's started, I get _really_ bad buzzing. Related weird side-effect: the sound from the buzzer under the dashboard is being transmitted through the CB's speaker.
Tried running the radio with a wire straight to the battery - no change at all, even to the buzzer-sound deal. Pulled out all the under-dash fuses, the noise went down a little but not much. As long as the Jeep's hooked to the battery, it's got interference, and a lot of it.
I keep wanting to say it's electrical and possibly related to a ground-loop problem I still have when trying to connect devices other than my in-dash CD player to the speaker amplifier, but 1. I disconnected the amplifier entirely just to make sure it wasn't the culprit, and 2. how can there be a loop when I run a direct line straight to the battery?
Anybody have any ideas?
