xj-armor electric fan override
edmaude
NAXJA Member #1368
West Milford, NJ
I did the lazy move and bought one of XJ Armors fan override kits. Seems like a great kit, but I can not get it to work. It is so simple all I need to do is run the one wire to a hot fuse and the other to the switch. Well, nothing is happening and have not heard back from Steve at XJ Armor yet. Am I missing something? Has anyone else installed one of these? Thanks
I have made better decisions in the past. Ordered the kit on Ebay on a whim even after reading all the feedback. Now that I have a switch and wire etc sitting around how easy is it to just do it myself w/o the relay?
Hi,
as i didn't found anything on the web about those kit I don't really know what you mean. But I think you want to manually switch the electric fan, don't you?
I installed this in my XJ 2,5TD (Diesel) too. The only thing was to install the switch. One cable to chassis-ground and the other to the relay which is switching the fan.
Maybe you can draw a small plan how you connected your swich. Also try top messure what you are switching. MAybe you also need chasis-ground to switch the fan?
Rainer :wave:
