Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Classic Full Size Jeeps SJ (1963-1991)
Classic Full Size Jeeps SJ (1963-1991) Technical forum for Jeep SJ-based vehicles, Full size Cherokee, Grand Wagoneer, and J-series pickups.
Old October 26th, 2017, 05:38
TRCobra506 TRCobra506 is offline
FSJ AW4 Swap
Joined naxja because of my aw4 transmission swap, looking for a few extra parts for the project plus I have a donor Cherokee to dismantle. I come from a family with a long history of running XJs, my mom used to run them on her rural postal route in RHD. Many miles were put on them trouble free. Since I had this low mile donor and was hunting overdrive lockup the swap was an obvious choice.
Here’s a copy of my thread from international full size jeep forums.
I’m starting to swap a aw4 from a 99 Cherokee into my 90 GW.
Contrary to popular belief the 97+ cherokee still has a stand-alone transmission control module.
I plan on using the np231 I have or a np242. The np229 looks like it might have overall length issues when used with the aw4. I’ll swap the speed sensor for the cable drive from my 229.
I will be using a Holley 2bbl with the Holley tps kit. I initially started fabbing up brackets to my motorcraft but my dad gifted me the Holley from another project. I’m not looking for more power so the 2bbl was a good reliable option.
Here’s where I’m at so far. I have the Tcm and wiring peeled out of my donor cherokee. There’s roughly 12 leads to the tcm. Brake light reverse light 12v constant 12v switched grounds. Some obdii connections. And two leads for the tps. I bought a 12v to 5v powersource for the reference signal on the tps. This used to supplied by the ecm.
Old October 26th, 2017, 06:11
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: FSJ AW4 Swap
Nice project keep us updated
Old November 9th, 2017, 16:36
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: FSJ AW4 Swap
Pretty cool, I love the big jeeps too.
Praise Marty Moose!
Old December 3rd, 2017, 21:03
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Re: FSJ AW4 Swap
thing looks insanely clean. Wish my wagon was that clean.
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old September 2nd, 2018, 07:14
auzjtruck auzjtruck is offline
Location: I live 80 klm north of Adelaide South Australia, in a little town named Owen
Re: FSJ AW4 Swap
are you still working on this
Old October 31st, 2018, 15:36
Re: FSJ AW4 Swap
Bump . We have a guy on my FSJ page doing the same swap. I am super interested in this since I have a waggy in the backyard and I always come across cheap XJ transmissions.
Old October 28th, 2019, 18:04
ghcoeii ghcoeii is offline
Re: FSJ AW4 Swap
Here are some threads with information on this swap.
http://www.ifsja.org/forums/vb/showthread.php?t=182007
http://theamcforum.com/forum/aw4-con...opic15549.html
Rate This Thread:
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 08:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
