Old May 7th, 2003, 13:14
Jamison Jamison is offline
Brake job question?
I have an '89 Limited that I'm trying to replace te front brake pads on. Does anybody know what size of allen wrench the caliper pins take? Please let me know, my brakes are grinding!
Old May 7th, 2003, 14:07
martin's Avatar
martin martin is offline
Jamison,
On my 88 XJ I have seen internal hex, trox and external hex (bolt head) pins used for the slider pins. My local garage gave me bolt type heads that take a 10 mm socket when I had the XJ in for front hub replacement.
Three years ago I had the entire brake system renewed and I needed new front rotors, mine were warped and too thin to turn. If your doing the job I'd suggest you replace rotors also.
I also have had several coworkers who had the rubber line deteriorate from the inside, form a check valve with a flap and lock up the brakes lock up when they were far from home. This may be smart money to change the hoses now and flush the system.
If you keep your calipers then just go buy the new caliper pins at the parts store and try to get the ones with hex heads and not the sockets that aways strip out. Then cut off the boot and use your vice grips to turn out your current caliper pins.
Martin
Old May 7th, 2003, 16:14
RTicUL8's Avatar
RTicUL8 RTicUL8 is offline
7mm
Old May 7th, 2003, 20:16
Thanks for the help, I got it taken care of. It was actually a torx fitting, but the manual said that it was an allen. It took me some frustration to actually get under far enough to see.
Brake Noise Urban Redneck Modified Tech Discussion 4 December 6th, 2003 20:18
Headers Question Garthbmn7 Modified Tech Discussion 1 December 6th, 2003 05:40
Brake Noise Urban Redneck OEM Tech Discussion 0 December 5th, 2003 14:51
Dana 44 brake hose question? BillR Modified Tech Discussion 3 November 17th, 2003 17:29
axle brake swap question RNMedic Modified Tech Discussion 2 May 30th, 2003 13:38
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
