Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > NACFest 2019
NACFest 2019 June 26th - 30th, 2019 at Rausch Creek Off Road Park, Tremont, PA
Old April 8th, 2019, 12:36
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
NACFest 2019 To-Do list
What the heck, I'll start it this year...
Thankfully, right now I have no "fix this or I can't drive it" issues, they're all more in the "nice to have" category:
1. Fix floors
2. Install Headlight Harness
3. Redo Driving Light wiring (relays melted a few years ago)
4. Check/adjust parking brakes
5. Update my CB remote mike cable extension (works, but I'm worried about robustness/fragility)
6. Replace passenger tail light sockets with 97+ sockets (just have to do the splicing)
And, of course, the most important thing to do on the Jeep (direct from the Department of First-World Problems):
7. Build a little door panel to cover that little cubby under the glove box on 84-96 models so I can move my older NACFest Dash Plaques down there and free up space on the glove box itself - I ran out of room on the glove box for new plaques after mounting the one from 2016!
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old April 8th, 2019, 15:18
2much2soon's Avatar
2much2soon 2much2soon is offline
Look forward to catching up with everyone.
Need to do:
Install warrenty replacement locker pumps once I get them .
Fluid changes on oil, and transfer case.
That's really it that needs to be done, but I'm sure I'll add to the want list and be stressing to get it all done last minute like every other year.
Sent from my SM-N950U using Tapatalk
Old April 12th, 2019, 02:14
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
Re: NACFest 2019 To-Do list
Just got my gas tank skid installed, so I can cross that off the list, only ordered it during a black Friday sale...
My air lockers were leaking a bit at Winterfest, need to take a look at that.
Address the front end a little more, it sits too high, I also need to adjust steering stops.
Put my winch back on whenever warn decides fix it and send it back to me...
The Rv needs the 2nd a/c wired up.
mac 'that's it for the moment' gyvr
MWC President / President
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
Old April 14th, 2019, 17:19
STROKER's Avatar
STROKER STROKER is offline
<-- A Tribute
Location: in my own little world, jus' dunno where it's at
Need to finish passenger side seat and 5 point harness install and maybe a new battery.
STROKER
MJ done...when we wheelin w/4.6 STROKER
Friend of Matt #17
RAUSCH CREEK
Old April 15th, 2019, 12:44
NAXJA Member #920
Got my headlight harness installed, just have to check/tweak the headlight alignment now.
1984 Dodge Omni
Old April 23rd, 2019, 15:44
Rock2pus's Avatar
Rock2pus Rock2pus is offline
NAC VP
Looking like Fiona needs a new battery and definitely rear leaf bushings...I have them now to knock the old ones out and do away with one of the clunks!
Old May 3rd, 2019, 08:48
xCWolf's Avatar
xCWolf xCWolf is offline
Bring the Boom
Done:
Aquire new (to me) XJ
Pull suspension from old XJ and install on new XJ
33" tires
Need to do:
SYE
Engine/Trans mounts
Make some Sway bar discos
Install CB radio
figure out a rear recovery point.
Come up with a solution for tool storage
Old May 20th, 2019, 12:57
NAXJA Member #920
When I did the headlight harness I swapped out what I thought was the one fried relay with a spare, over the weekend I finally had a chance to play with the lights and I've confirmed that pretty much all the wiring is shot.
What I have now:
1. Trigger lines tapped off both high and low beam wires on D/S, each passes through a weatherproof ATC Mini-Fuse holder and the two lines go together to relay #1 to trigger the lights. Only one of the ATC-Mini holders has a fuse, I move it to select low- or high-beam trigger (put this in to satisfy NJ inspection years ago, so my "fog lights" were properly triggered by the lows, but still allow easily changing back to triggering off the highs as per install instructions once I had my sticker).
2. OEM foglight switch on dash (truck did not have originally, added) triggers relay #2 for independent manual activation of lights.
Both paths are inoperative - seeing voltage at both ATC-Mini fuse holders, but the wiring from there to the #1 relay is toast. Similarly, no power getting from the dash switch to the #2 relay (which turned out to ALSO be dead), and nothing's getting through to the lights from either relay, and both light bulbs do work. Since I used non-sealed splices to put the original wiring together, everything between the ATC-Mini holders and the lights, and everything between the dash switch and the lights must now be redone.
But redone it will be, with proper heat-shrink-sealed connections and a nice aux. relay-and-fuse box (researching those online), so I can get it fixed properly.
Between getting the Hellas working and the relay harness on my main lights, this thing's gonna be able to signal the Moon when I'm done...
1984 Dodge Omni
Old May 24th, 2019, 02:48
Victor S. Victor S. is offline
Things I need to Do:
Install Lift
Install Cb
Change Fluids
Install rear disc conversion and redo brake lines
Old May 24th, 2019, 02:49
Install Lift
Install Cb
Change Fluids
Old June 1st, 2019, 16:40
xcalibur223's Avatar
xcalibur223 xcalibur223 is offline
NAC VP
Finish the rear disc conversion
Bleed brakes
Alignment
Get inspected
Hope it drives ok still and nothing else breaks
Originally Posted by Begster View Post
(And don't listen to a big red head who looks like hellboy, and answers to the name Ross, he doesn't actually know what he is doing!)
Old June 1st, 2019, 19:25
macgyvr's Avatar
NAXJA Member #120
I am down to wiring up the second a/c in the rv and washing my jeep and doing a little clean up from a wheeling trip last weekend...
mac 'I think/hope' gyvr
Old June 7th, 2019, 15:48
NAC VP
Originally Posted by xcalibur223 View Post
Finish the rear disc conversionDONE
Bleed brakes DONE
Alignment DONE
Get inspected
Oil Change
Fluid checks
The disc brake conversion worked out and I have an ebrake for the first time in this jeep. Still need to take it above 30 to see how it drives but for now I'm just about set.
Old June 8th, 2019, 02:30
Install Lift DONE
Install Cb being done this weekend
Change Fluids
Install rear disc conversion and redo brake lines Will do in the future
Old June 8th, 2019, 08:29
xCWolf's Avatar
Bring the Boom
I'm down to rear shocks. the difficult part is going to be finding motivation to do it.
Rate This Thread:
NacFest 2019! It is official! June 26-30! Rock2pus North Atlantic Chapter 95 June 27th, 2019 10:17
NacFest 2019! PLEASE READ!!! Rock2pus North Atlantic Chapter 30 July 23rd, 2018 15:48
NacFest 2019 ! Information and Explanation! Rock2pus North Atlantic Chapter 10 June 27th, 2018 12:39
