Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
Old April 10th, 2019, 12:28
mage's Avatar
mage mage is offline
2k XJ w/270 miles, shud I upgrade it?
Not sure if it's smart to put 5K axle/gear/disc in her with 270k miles?
What do you guys think?
Old April 10th, 2019, 17:45
Anak's Avatar
Anak Anak is offline
Stranger
Re: 2k XJ w/270 miles, shud I upgrade it?
How is the rust?
I think there are quite a few folks who are investing more than $5K in these vehicles. On the one hand, we like the platform and want to continue to enjoy it. On the other hand, if something happens to this particular chassis the parts can most likely still be pulled out and put into another chassis.
Baby it's cold outside.
Old April 10th, 2019, 17:58
Ronbo's Avatar
Ronbo Ronbo is offline
Not a big deal, IMO. I just put a D44/D60 into my 98 that I've owned since new. I don't see getting rid of it and figured it's a lot less money than I would have spent on another rig.
Build it right and invest in good parts and you'll want to keep it. If something happens to it, take the good parts and put them on another XJ.
98 4.0, AX15, 241OR, RJ44/RJ60, Poly 3-link, Nationals, 35s.
Old April 10th, 2019, 19:34
mage's Avatar
yeah See... I have no attention to getting rid of it, ever.
SoCal Jeep no rust, but the sun baked off some top coat.
Runs great right now. I do have problems tho. She overheats when driving uphill. Misses on cylinder 1 sometimes. I had some electrical work done on it. The harness is rotten in spots. But 2 weekends ago I driving up to Big Bear. Ran she strong the whole time. I stopped for a break. When I pulled out I got a miss 1 and 6. Jeep sat, since my boy drove mostly that weekend, no wheeling intended. I get back in to leave the light is gone and continues to run strong without any light reappearing since.
Not sure if it's the time for a rebuild?
I need to get her locked not make her new again. But then I don't need to be in the sticks with engine trouble either... AAAAAAAHHH.
Old April 10th, 2019, 21:57
smccollamjr smccollamjr is offline
Rust free XJs are getting tough to come by. If you plan to keep it put another motor in it if necessary. When we bought the one my son drives I was more concerned with rust than miles. Found one with 218k with no rust. I figure if I get another 100k out of it, great. If not Iíll find a used 4.0 and slap it in. Personally, I rather do that than chase the devil we call rust.
Old April 11th, 2019, 13:16
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Symptoms sound like heat soak on the injectors. Wasn't there a TSB for this?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old April 22nd, 2019, 12:13
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
The early XJs didn't have heat shields aorund the injectors, the newer ones did. Even then, somethimes it was an issue.
I made the mistake of cutting in hood vents on one Jeep. It only made the problem worse as it would pull the hot air past the intake.
So I mounted a fan in the vent above the intake. When I stopped, I would start the fan and let it run awhile, which took care of the issue.
To the OP:
If the body is in good shape, and the vehicle doesn't owe you anything, I would mod it the way you want it.
$5K is nothing in the scheme of things, and if you do some cleaver junk yarding/parts swapping you can accomplish your goals for a lot less than that.
Old April 22nd, 2019, 13:23
mage's Avatar
That was the plan for years, but I lost the garage in the divorce.
Old April 22nd, 2019, 15:02
NAXJA Member #920
O/P has a 2000, so I'd expect the TSB to apply because I think it was specifically targeted at something in the 97-01 range.
1984 Dodge Omni
Old April 22nd, 2019, 15:13
mage's Avatar
so I was at the dealership with the jeep recently, they would be very quiet about an active TSB, wouldn't you think?
Is there a quick way to find the TSB?
Old April 22nd, 2019, 15:39
NAXJA Member #920
Tried a quick search on the boards here, did turn up this about adding a timer function to run the electric fan after shutdown to combat the heat soak issue:
https://www.naxja.org/forum/showpost...53&postcount=8
Longer thread on same thing: https://www.naxja.org/forum/showthread.php?t=1028190
then there's this: https://www.naxja.org/forum/showpost...1&postcount=12
But I think this is it: https://www.cherokeeforum.com/f2/jee...6/#post1409821
1984 Dodge Omni
Old April 22nd, 2019, 16:44
mage's Avatar
You sir, just Rock!
Old April 22nd, 2019, 19:59
mage's Avatar
D44, disc breaks, 30 spine Axles, 4.56, fNboutTime Locker, Eton Detroit, go'n limited slip. (Explorer, DD) 5K? all brand new? yeah?
Old April 22nd, 2019, 20:03
mage's Avatar
regear front too... of course
Old April 22nd, 2019, 20:29
mage's Avatar
I want 33's but gas is $4 a gal. Tax is 60 cents a gal. WTF, anyway I was having a streering shake at 50mph. Go for a balance. Tire (Young) guy said he had to use and I quote a "Ridiculous Amount of weight". Does Ridiculous still mean, Ridiculous?
Rate This Thread:
WJ power steering pump upgrade vs PSC pump upgrade hot_rod_hooligans Modified Tech Discussion 52 April 24th, 2019 12:27
88 Xj: Brake Upgrade Questions due to Axle Upgrade RAVC1 OEM Tech Discussion 7 August 9th, 2012 06:45
20K miles... IXNAYXJ NorthWest Chapter 48 November 6th, 2007 18:23
How many miles is too many? LeftCoastLax OEM Tech Discussion 5 June 20th, 2007 07:31
Upgrade 96 to 99+ Intake. Upgrade injectors, too? BigG OEM Tech Discussion 4 February 7th, 2007 22:53
