AW-4 and 242 HD Rebuild Options?
DPG
Kansas
Hey guys,
Putting a Golen 4.6 stroker in my XJ in a few months and looking for options to rebuild my AW4 trans and 242 t-case, since they are approaching 260k miles.
Any kits available to increase line pressure to strengthen the AW4 to hold up to that stroker better? Other mods? Not looking for race car shifts, but stronger and better reliability.
Should I just rebuild my 242 t-case or is there a better bolt-in HD option?
I'm a suspension guy primarily, so any advice on this is much appreciated.
Thanks!
Dirk
I was corrected on pg2 that I used their stage 1 clutches!!
Hey guys,
Thanks!
Dirk
There is a 242HD. I believe it was used on Select-Trac WJ's with either of the V8 options.
Finding the 242 from the V8 WJs is tough and expensive. I put one in my WJ. I lucked out when I was searching and found one decently quick and not terribly expensive. Otherwise plan to be on the hunt and drop 300+
if you wheel that xj find you a ruby 241 , bolts right in the xj , super strong w/ the 4.1 low range. great t-case.
Thought I read that the 241s don't have the provision for the speedometer gear drive like our XJs use - maybe I'm misremembering?
There was a change in the latter years, and the early model needs a Dakota Digital converter for our use. Here's the NIB TJ 241OR I bought from JB Conversions!
The TJ 241s just have a tone ring with sensor pickup, but there is a module you can install inline between the case and the harness and it'll work just fine. https://webshop.healtech-electronics.com/shop/sh-v4a/ is the module, and SHA-J01 is the plug/harness that goes with it. Since it's programmable, you can adjust it for any kind of deviation, or anytime you change gears or tire sizes.
The newer JK/JL 241s have no speedo provision at all since they're loaded with electronics and have speed sensors at the wheels instead.
Rcp i thought you were on some good stuff was thinking no way you paid for a 241 like that, zooming in on pic i was like holy shit that isnt a 231. Must have cost a shit ton.
The WJ 242HD is also an odd input spline count if Im remembering correctly.
And they were rare when I was looking for one ~10 years ago, I can only imagine that has gotten worse as the WJs have dried up.
I think its very similar to the Durango NP242.
The WJ and Durango of the same era used the same engine, transmission and tcase on some trim levels, but each unit is slightly different. IE the 242 is the same, but uses a different input spline count. Why? WhoTF knows. :gee:
Here is a pretty cool swap, Im hoping Im allowed to link to another forum?
https://www.cherokeeforum.com/f67/wj-np242jhd-transfer-case-96-xj-265240/
Remember the '91+ XJs are a 23 spline transmission output, while the '90 and below are 21.
I bought it when the Rubi TJ first came out so there wasn't any in the junk yards yet. I paid $1700 for it which I thought was a great price for a NIB transfer case!
