OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
I have noticed an accumulation of motor oil at the bottom of my 1990 xj whenever I park. I checked under the vehicle and under the hood, I do believe the leak is coming from that piece that the oilfilter is attached to. Does this have seals that can be replaced, or do I need to replace the entire piece.
1. what is the name of it, and what do you suggest I do? |
#2
Re: leaking in area of the oil filter
Three o-rings, shouldn't cost more than $5 at the dealer. It can be a pain to get the bolt out of the adapter. You'll find discussion about this if you do a search.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Oil comparison? | brtb | OEM Tech Discussion | 12 | March 22nd, 2004 23:43 |
Oil Filter won't fit block! | ADam J | OEM Tech Discussion | 8 | February 23rd, 2004 20:48 |
help oil filter adapter/elbow leaking | tbear | OEM Tech Discussion | 3 | September 27th, 2003 15:25 |
Oil leak in area of oil filter, need help | gman | OEM Tech Discussion | 8 | June 5th, 2003 14:12 |
OIL in the distubuter?!?!?!?!?!? | Stoney | Sierra Chapter | 5 | March 4th, 2003 04:24 |
