Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
  #16
Old October 3rd, 2018, 09:01
RCP Phx RCP Phx is offline
Re: Rebuilding a 4.0
Update on where your at with this.
Old October 3rd, 2018, 21:50
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
In due time, the mad scramble for Moab has been eating up more time than anticipated.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old April 2nd, 2019, 14:20
Update.......
Old June 2nd, 2019, 12:23
This project die?
Old June 4th, 2019, 09:10
Coffee Drinker
It hasn't died, it's just on hold waiting for a head from Russ.
Old July 17th, 2019, 08:42
CSpeade51 CSpeade51 is offline
nice thread so far
Old July 17th, 2019, 10:11
old_man's Avatar
old_man old_man is offline
I decked the block on mine and I am running H802CP pistons. I am running an old Crane cam and a Clifford header with 2.5" exhaust. I over bored the throttle body as well. I love it. It runs on any grade gas with no ping and I have 250k miles on it.
My best recommendation is to get an AFR gauge and install it on your vehicle. I find it helped dial things in the best. Mine is a Renix and I run a MAP adjuster I designed myself and I can dial the fuel exactly where I want it without a dyno and it has helped me catch a bad sensor a couple of times that would throw the computer into open loop mode. When everything is dialed in, I get 21mpg on the freeway on long trips and 18 mpg pulling my teardrop.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Rate This Thread:
rebuilding an 8.25 LSD? ehall OEM Tech Discussion 3 June 14th, 2016 10:07
Rebuilding an AW4 smcdonaldaz OEM Tech Discussion 4 January 24th, 2009 13:40
WTB: fox 2.0 rebuilding xcm SoCal Chapter 2 November 28th, 2008 21:31
Rebuilding AX-15 MattAnonymous OEM Tech Discussion 1 November 4th, 2007 21:13
rebuilding an AX-15? woodbutcher Modified Tech Discussion 4 December 18th, 2006 19:10
