Placed An Order
MontanaXJ
Montana
I just placed an order from DPG Off-Road. I ordered the RE/DPG 5" Hybrid Kit and upgraded to the RE adjustable upper and lower arms. I went with the OME long travels all the way around with the ZJ rear. I also got an OME stabilizer. JKS BPE's front and rear. DPG Rock Attack gas tank skid and T-case skid. Advance Adapters HD SYE and a High Angle Driveline CV Driveshaft.
Is has begun...
You win the lottery?
Harvo said:
Why did you decide to get adjustable arms over the ones that come in the kit?
Adjustables allow for fine-tuning wheelbase and pinion angles
91 Jeep Project said:
Because they are better, or is that answer to easy for you????
Adjustability would have been the better answer.
Anyway, with adjustable upper and lower arms you can play with pinion angles and caster a little bit as well as wheelbase. It also allows you to adjust when you change front axle assemblies.
