I have a 1992 Jeep Cherokee Limited with ABS and power brakes. When the Jeep is at operating temperature, i.e. driven for 15 minutes, the brake pedal does not fully retract after the brakes are applied and therefore the brakes and tail lights remain on. The brake pedal does not get 'mushy' even when it doesn't return. I can pull the brake pedal back up, but the same thing occurs each time the pedal is depressed.
When the Jeep is cold, the brake pedal retracts as normal.
The fluid reservoir is full, the wheel cylinders and calipers are not leaking. I tested the brake booster as per the FSM and it passes and I have bled the brakes.
Any idea on what could be causing this?
Thanks,
Jon
Thanks,
Jon
