I've been changing my speedo gears, but haven't got the right one. Used Go Jeep's charts and took the plunge to 40 tooth. I know I have to index the housing. The range I am in is 34-38. The next is 38-42. My question is this. There is a dot on the case that I assume is the reference point, but the range I am in now is not lined up to it. I can only rotate in 90 degree increments. should I just rotate the housing 90 and put the 38-42 range close to where it is now, or does it have to line up with the dot on the case. Is my speedo going to be off if I don't get the right range? Thanks
