99 sport 5 spd ABS front diff
Chadc72
Ct
Hello,
My front differential assembly had an unfortunate meeting with a boulder. I am trying to locate a replacement, but it seems that this particular combination (5 speed, ABS) is difficult to find. Does anyone happen to know a good place to find one, or can an automatic version simply be re-geared with the proper 3.07 ratio?
Thanks for the help!
-Chad
Someone will correct me if I'm wrong here but, I'm pretty sure the housing is pretty much the same on all XJ D30's ABS or not. You can even use the low pinon from the 2000 2001 if low pinon vs Hi pinon isnt an issue with you. Difference is low pinon will require the correct gear set.
I don't know the ABS systems too well, but if your tone ring equipped shafts were not damaged in the meeting, you could always swap them (along with any other abs parts on the axle) into the axle you purchase.
