Old March 21st, 2004, 21:07
JBrobeck's Avatar
JBrobeck JBrobeck is offline
Cool Head porting (pictures inside)
I spent an ungodly amount of time cleaning up the intake and exhaust runners on my newly aquired H.O. head, I could not believe how much extra casting there in the runners! it may not look like much material was removed, but it was more extensive than it looks like in the pictures.
I am curious (for my own sanity) to know if all of this work was in vein, or if it will at least net me a little HP/gas milage, I will also be adding the late model equal length runner intake manifold and H.O.throttle body.
Pictures are here...
Intake Ports
Exhaust Ports
View from combustion chamber
Thanks in advance for any input, I can't wait to get this thing up and running again, the New Crane cam, .040 pistons and H.O. conversion ought to be a hoot, hehe, I have a $200 Jeep with a $1000 motor, go figure!
Josh
Old March 22nd, 2004, 04:48
rsalemi rsalemi is offline
Re: Head porting (pictures inside)
Whats an ungodly amount of time? I spent about 20 hours on mine. A couple of suggestions - do a 3 angle valve job and back cut the intake and exhaust valve and you will pick up the flow even more. as far as improving mileage - thats not what you are accomplishing - you will be making more horsepower (throughout the RPM range but mostly at the high end).
Old March 22nd, 2004, 07:01
JBrobeck's Avatar
I've got about 14 hours into it right now, and I haven't done the valves yet. I could have had the motor assembled, installed and drivable in half that time, so I was just curious as to if this was really worth my time .
As far as a 3 angle valve job goes, how much would a machinist usually charge for that? I would immagine its not somthing I could do myself as I can't think of any at home valve/seat cutting tools.
When you say back cut the Valves, what does that entail, removing some of the material at the base of the valve?
Sorry if these are dumb questions, but I have never done any headwork before other than lapping the valves during a rebuild
Thanks for you help
Josh
Old March 22nd, 2004, 10:24
rav's Avatar
rav rav is offline
Looks awesome, i will be doing the same to mine too, can you measure the port sizes and let me know, i am porting my 99 Head and the gasket fits perfectly on the intake ports but the exhaust ports and way small, like my renix head.
Thanks;
Ravi
Old March 22nd, 2004, 12:07
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
You've opened up the ports pretty good there Josh. All you need to do is smooth away the rough spots so that the air takes a smooth flow path and there isn't too much turbulence, especially on the exhaust side. You can leave the intakes a little rough to aid fuel atomization.
Old March 22nd, 2004, 19:45
JBrobeck's Avatar
Now do I want to go ahead and open up the exhaust ports more or just leave them as is, I don't wanna take away too much bottom end, but If it will really gain me in the top end, it may be worth the effort, I am this far into it and I would really like to do it right ONCE, not have to do it again!
Thanks
Josh
Old March 23rd, 2004, 05:41
Re: 3 angle Valve Job
Find a competent (hard to do) machine shop for the valve job. 3 angle not that much more than standard and if you don't have acces to valve equipment you need to farm it out anyway. Back cutting is removing material from the bottom of the valve (the side in the port - not in the chamber)
4.0 HO head, and intake 96 XJ Fletch For Sale: Private Party Only. XJ ITEMS ONLY 4 March 21st, 2004 15:48
Head repair.. Jeranta OEM Tech Discussion 5 February 19th, 2004 14:25
Head Porting question rws Modified Tech Discussion 2 October 25th, 2003 05:20
Head porting? mcconnaughey Modified Tech Discussion 10 May 31st, 2003 23:36
Head count for people planning on attending Kevin W.'s...... WesternXJ Sierra Chapter 4 July 3rd, 2002 22:42
