waggy 44 build
JeepinCoastie
jersey shore
You need the UCA mounts for the axle too. I thought Ruff Stuff had all of the front axle brackets needed, Give Dan @ Ruff Stuff a call, he'll probably work a package deal for you. Tell him your a member here...
A.
A.
I was thinking of his backets for the rear ... but i really like those coil bucket setups with everyhting included ...
will call dan for the tabs though i have his diff covers and i know he has an awesome product
Made some changes to the set up
For the front Im going to stay with the Ballistic mounts that will take care of the springs, shocks, and LCA's
http://www.ballisticfabrication.com/XJ--TJ-Jeep-combo-bracket-upgrade-kit_p_1542.html
And use the RE Bridge and UCA mounts
http://rubiconexpress.com/builderparts/Product.aspx?folder=BPBK&part=RE9968
As for the Rear im going to use Ballistic again for the springs
http://www.ballisticfabrication.com/Leaf-Spring-Conversion-Kit_p_1699.html
and these for the shock mounts.
http://www.polyperformance.com/shop/Universal-Fit-Lower-Shock-Mount-p-19074.html
