The 8.8 Simple Swap kit!
Dan Fredrickson
Sacramento, CA
This is the minimum needed to swap an 8.8 into your XJ.
It comes with a pair of our correct size spring perches in a length long enough to help with Axle Wrap. A pair of Ubolt plates, 3/8" thick with 40 degree bends on the ends so you can rely on their strength. 4 Grade 8, 5/8" Ubolts with proper hardened washers and ubolt tallnuts. And we add a pair of shock brackets to replace the stock ones on the axle.
These are one of our most popular products with XJ guys. We have the Swap kits for just about any axle!
I bought this kit from Dan for my MJ and it rocks! Thanks again Dan and if you want some installed photo's let me know and I can get some for you.
A little known secret about our Swap Kits!
You can add a diff cover to the kit you want a a big discount!
for the D44's its only $85 to add the cover......
$95 for the D60's or 8.8's......
$100 for the 14 Bolt swap kits......
AND.....the shipping cost is still $10:shhh:
Re: A little known secret about our Swap Kits!
Keep this in mind if someone wants to buy you something heavy!
What is that? i was lookin at my comanche when i bought it and it was missing the linkage. what does it do???!!!
