Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor's Specials
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old April 8th, 2009, 18:46
AJsArmor's Avatar
AJsArmor AJsArmor is offline
Bumper mounts, d-ring tabs, DIY parts are HERE!
This is the beginning of our entirely new DIY product line. The same high quality mounts and pieces we use on our own bumpers are now available for those wishing to build their own. Can save you a lot of time and aggravation! Everything is CNC laser cut for the utmost in quality and consistency. Our new tire carrier hinge is nearly ready to be released as well, puts the spindle mounts to shame!
Front Bumper mounts, incorporate a steering box support on the driver's side this setup has proven itself over the years on our own bumpers. 1/4" thick steel, 17" in total length.
$45 shipped to your door for the pair
Rear Crossmember Mounts, constructed from 3/16" plate they're a good start to a rear bumper using the factory mounting points. Our framerail mounts will be available shortly.
$23 shipped to your door for a pair.
D-ring Mounts, 3/4" thick steel with a 1" hole works perfectly with 3/4" shackles that have a 7/8" pin. (We will have those shortly as well). Long enough to extend through a bumper, same way as we do ours for the ultimate in strength!
$35 for a pair shipped to your door.
The "Harpoon" D-ring Mount, 3/4" thick steel it has a more flared look and still retains the strength of the pass through mounts, best of both worlds!
$40 for a pair shipped to your door.
Also our SuperRails outer tube, pre-bent and cut out of 1.75" round tubing with the supports $75 shipped for the pair! Pics coming soon. Call/PM/Email me for a package price for multiple pieces. Check back often as we're adding more pieces soon!
Old April 10th, 2009, 13:07
Jimbo_1321's Avatar
Jimbo_1321 Jimbo_1321 is offline
Re: Bumper mounts, d-ring tabs, DIY parts are HERE!
I'm stoked on these!
I'll definitely be ordering some stuff.
I'm just waiting for the tire carrier hinge
Old April 10th, 2009, 14:02
AJsArmor's Avatar
I should have a final pic of the hinge kit next week. Made some slight changes to it so it could be more universal and the hardware much cleaner looking.
Old April 12th, 2009, 22:19
srmitchell's Avatar
srmitchell srmitchell is offline
So is the outer tube setup what I would want to upgrade my standard to super rails?
Old April 12th, 2009, 22:37
AJsArmor's Avatar
Yes, I'll snap a pic tomorrow and post it up. Would be the outer tube, all bent and cut to size plus the inner supports notched. We do any length.
Old April 13th, 2009, 18:42
Glenn B's Avatar
Glenn B Glenn B is offline
Admin and Member #69
With the front bumper mounts... being 1/4 thick, is that a problem using stock bolts?
2001 4door XJ. 4.5 inch long arms, 33x12.50-15 Mickey Thompson Baja MTZ's, Superchips Flashpaq, bigger throttle body, AFE cold air intake, Advanced Adapters SYE, and a ton of stuff still to do on this project!
Old April 13th, 2009, 22:03
AJsArmor's Avatar
For the steering box most people have said no. But I do have longer steering box bolts available that I'd throw in for free anyways.
Old April 13th, 2009, 22:11
Glenn B's Avatar
Great! I need to order a pair from you. I did not see (at a quick glance) how to order them from your site, so I will try to get a hold of you tomorrow to get some coming this way. :-)
Old April 14th, 2009, 06:11
AJsArmor's Avatar
Site is being reworked, slow going because it's being done by me.
EMAIL me or feel free to call 563-924-2286. I'm working solo for awhile so if I don't answer just make sure to leave your name/number and I'll buzz ya back asap.
Old April 15th, 2009, 13:51
stewie's Avatar
stewie stewie is offline
are those front bumper mounts the same you use for your winch bumpers?
Old April 15th, 2009, 23:35
AJsArmor's Avatar
Yes. The only addition is that we add a plate to the underside of the framerail with another mounting hole. We were just going to have that all one piece and bent. But decided against it because of all the variations of bumpers.
Old April 16th, 2009, 20:19
foxwar71 foxwar71 is offline
Anymore updates on the tire carrier hinge?
Old April 17th, 2009, 06:06
AJsArmor's Avatar
Had a setback with the main pin. We originally were just going to use a socket head cap screw but the smooth shank part of it wasn't quite the fit we wanted with the bearings. So I'm just going to do it right and use a shoulder bolt that has a 1" shoulder, and 3/4" threaded section. They're designed to be used for bearing applications so they fit perfectly. Expensive, but it'll be done right. Have them on order so they should be here next week. That's all I'm waiting for!
Old April 17th, 2009, 12:40
Sweet!!! I'm looking forward to ordering a couple of these to use on the bumpers I'm building.
Old April 17th, 2009, 21:57
XJNoah's Avatar
XJNoah XJNoah is offline
Would you sell just the passenger side bumper mount? I have a c-rok steering brace I'm going to build off of on the driver side and just need a passenger. thanks.
Rate This Thread:
Front reciever, D-ring tabs, or both? terryd Modified Tech Discussion 6 March 17th, 2008 21:20
D-Ring Tabs dgrigorenko Modified Tech Discussion 2 January 19th, 2008 19:49
Tow bar to D-ring tabs bl87xj Modified Tech Discussion 3 August 21st, 2007 10:23
Custom 4x4 Bumper/Tire Carrier and D-ring mounts BornAgainXJer Modified Tech Discussion 3 September 20th, 2004 07:48
NORCAL: BPIfab Rear bumper, tire carrier, hitch, D-ring tabs $600 - '96 and OLDER basalt51 For Sale: Private Party Only. XJ ITEMS ONLY 14 November 24th, 2003 16:25
