Old September 23rd, 2006, 16:22
black2door's Avatar
black2door black2door is offline
02 sensor code....Bank 1, Sensor 2
Hey, I went to O' Reilly today and had my check engine code read it said "Bank 1 Sensor 2 Oxygen Sensor" is that the "before cat" or "after cat" sensor. The guy at O'Reilly said he had no idea call the dealership, but I thought you guys might know.
THANKS!!!
Old September 23rd, 2006, 19:38
RVA16v RVA16v is offline
Re: 02 sensor code....Bank 1, Sensor 2
THANKS!!!
After the cat. Cheers
Old September 23rd, 2006, 20:17
black2door's Avatar
THANK YOU!!!
Old September 23rd, 2006, 21:15
Ben H's Avatar
Ben H Ben H is offline
check your fuses first.
Old September 24th, 2006, 00:11
After 10 years of being a tech....Have I missed the creation of the O2 heater circuit fuse??? IF there was a fuse problem Im sure would would have been an "Open circuit" or " short to" code. Correct me if Im wrong...Please. (no sarcasm) If theres is a fuse thats related to the O2 Id like to know, and Id like to know where in the preheating (Im assuming thats what it would be) circuit it would be.. Also to double check, you can always monitor the output of both O2s and see what their readings are before you replace.
Old September 24th, 2006, 00:26
Ben H's Avatar
On my 2000 there are 2 fuses that have given me PO135, PO138, PO141 codes. When I first pulled the codes I replaced the sensors to no avail, then found out about the fuses. (I have an excuse on the 2000 it is nearly impossible to find a fuse diagram without a FSM). I don't know what year you have but....
Old September 24th, 2006, 00:28
What do the fuses control? I havent run into this before and the more knowledge the better.
Old September 24th, 2006, 00:45
Ben H's Avatar
Heater circuits. There is a 20 amp and a 15 amp in mine that control the heater circuits.
Old September 24th, 2006, 01:49
Thats what I figured... Thanks man.
Old September 24th, 2006, 09:50
Ben H's Avatar
The 15 is in the interior kick panel and the 20 is under the hood.
02 sensor code LilRedRover OEM Tech Discussion 8 June 4th, 2006 11:11
Another PO138 code thread.. and again it wasn't the O2 sensor Huerito OEM Tech Discussion 6 December 26th, 2005 12:26
IAT Sensor Relcation and Code p0113 (yes i searched) CommandoXJ96 OEM Tech Discussion 7 August 8th, 2005 23:29
O2 sensor code p0152,p0155 njedgexj OEM Tech Discussion 0 May 3rd, 2005 07:24
O2 Sensor - OBD code 0138 Zoner OEM Tech Discussion 2 August 18th, 2004 12:45
