Old August 18th, 2007, 16:15
bl87xj bl87xj is offline
I have not Confirmed, or I used a BAD email Addy
Tow bar to D-ring tabs
Can't find a tow bar that will mount to d-ring tabs, or even one that I can modify the hardware on.
Anybody have a tow bar that mounts to their d-ring tabs? Tell me how you did it.
Old August 18th, 2007, 16:25
scottmcneal's Avatar
scottmcneal scottmcneal is offline
The 97 Club
Re: Tow bar to D-ring tabs
try Tomken machine( tomken.com) He has a tow bar that mounts the way your talking i think
Old August 18th, 2007, 22:35
Thanks,
That might work if the spacing matches my D-ring tabs. Hopefully they reply to my e-mail.
Anyone have one and want to measure it?
Old August 21st, 2007, 09:23
JonnyK JonnyK is offline
I have a Demco "Kwik-Tow" tow bar that I mount to my D-ring tabs. The width is adjustable and the arms fold completely together for storage. Because the tow bar has 1/2" holes and the tabs have 3/4" holes, I bought some flanged brass bushings with 3/4" OD and 1/2" ID to put in the D-ring holes and 1/2" bolts (grade 8) with nylock nuts and washers to bolt it together. Works great for me.
Can / should OE door hinge tabs be used for tie in to firewall RWKHausSupply Advanced Fabrication and Engineering 5 January 19th, 2007 07:19
anyone here make custom tabs? joshbish Modified Tech Discussion 2 February 21st, 2005 21:15
source for Heims, weld on tabs Danno Modified Tech Discussion 7 February 21st, 2005 12:27
NORCAL: BPIfab Rear bumper, tire carrier, hitch, D-ring tabs $600 - '96 and OLDER basalt51 For Sale: Private Party Only. XJ ITEMS ONLY 14 November 24th, 2003 15:25
Need a link for mounting tabs, FAST 4ward Modified Tech Discussion 7 September 25th, 2003 19:25
