Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor Advertisements
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old December 20th, 2012, 10:33
Clayton Off Road's Avatar
Clayton Off Road Clayton Off Road is offline
Clayton Off Road
Clayton Off Road Long Arm Upgrade!
The Clayton Off Road long arm upgrade kits are perfect for anyone who has a lifted Jeep, and is looking for that next step. Our kit is intended for anyone who has a short arm lift and wants to upgrade to a high quality long arm suspension system.
Our kit comes with a 3 piece cross member, as well as upper and lower adjustable control arms.
The 3 piece cross member bolts into the oem location for alignment purposes, then welds on for strength. It features a removable center section if your drivetrain needs to be serviced without having to remove any suspension components.
For more information, pictures, and available options, visit our website: Clayton Off Road Long Arm Upgrade.
Alex
Marketing Director
Clayton Off Road
Old January 4th, 2013, 13:50
Clayton Off Road
Re: Clayton Off Road Long Arm Upgrade!
Bringing this one back up, let us know if you have any questions!
Alex
Marketing Director
Clayton Off Road
Old January 5th, 2013, 15:04
Smash Hole Smash Hole is offline
GFY
I bought one of the 3 link kits a while back and finally got it on. Is there a reason you guys don't use a left hand and right hand joint to allow easy adjustments of the links?
Also how long can I safely adjust the upper?, I think I may have to fab up a new one to get the wheelbase I want out of it.
Thanks
Old January 5th, 2013, 20:34
bluejeepkid bluejeepkid is offline
Originally Posted by chettacheez View Post
I bought one of the 3 link kits a while back and finally got it on. Is there a reason you guys don't use a left hand and right hand joint to allow easy adjustments of the links*
Thanks
Wondered the same thing
Old January 6th, 2013, 09:58
GFY
I was extremely disappointed when I figured that out. It's a great kit all around but IMHO it is a huge downfall that needs to be taken into consideration when choosing your long arm system.
Old January 7th, 2013, 17:59
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Thanks
How hard is it to pull one bolt, like any other adjustable arm?
With LH/RH ends, there is always a possibility of movement/unwanted adjustment if a jam nut gets loose.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old January 8th, 2013, 01:20
Redxj5150's Avatar
Redxj5150 Redxj5150 is offline
The fact that it's a 3 link probably makes that tricky a little tricky.
Do you guys offer any kind of a discount for members? I'm becoming more and more interested in your 3 link kit.
Looking in your pictures I notice the upper link seems awfully close to the driveline. Have you had any customers that have had problems with clearance at full droop?
Travis
99XJ
67Commando
Old January 8th, 2013, 10:15
Clayton Off Road
Like Johnnie Walker said, we don't want the link to unthread itself while in use.
We haven't heard anything yet from our customers yet about the link hitting the driveline using a HP30.
Alex
Marketing Director
Clayton Off Road
Old January 8th, 2013, 17:46
GFY
It's a pain in the ass Johnny. Trying to adjust your wheelbase and caster when it's on a rack, and when you pull the single upper and the whole axle rotates. I've never had a link loosen up on me and I've never had my steering or track bar links loosen up either. Do you pull your steering apart when you need to adjust toe or trying to center the steering wheel?
Perhaps I was just expecting something a little more well engineered. Maybe you guys could offer a LH/RH option? I'm obviously not the only one who questioned it.
Old January 8th, 2013, 21:09
Piece of Fish!
From a manufacturing point of view, less time, effort, parts go into using the same parts both sides.
Old January 8th, 2013, 21:16
in4aride in4aride is offline
Do you offer the xmember with the upper mount on the passenger side? I didn't see anything on the site.
Old January 9th, 2013, 18:04
GFY
It's a Clayton kit, not some Rough Country or other starter kit. I expect more, as you put it, "time" and "effort" to go into this system.
It's obvious you have no experience with this 3 link system. I don't want answers from you nor are my suggestions directed at you.
Old January 9th, 2013, 20:49
Andy in Pa.'s Avatar
Andy in Pa. Andy in Pa. is offline
NAXJA Member #180
I have 12 years of experience with Claytons long arms, and have only adjusted my long arms twice. Why risk putting some kind of turnbuckle type of adjustment into it, and possibly putting another failure mode into it, when its going to get adjusted once, maybe twice over its life span. I recently changed my adjustment, and even with tweaked crossmember mount pockets and 12 years of rust/dirt/grease it took me 1/2 hour to drop the arms, adjust each long arm, and bolt them back down.
"I can get you in...."
Old January 10th, 2013, 07:39
GFY
Judging by your 12 years of experience, you are not dealing with a 3 link. You are not pulling the single upper and having the whole axle twist on you while having it on an alignment rack.
I'm not running oem axles so the suggested starting points were not even close. Pulling the link, adjust, and trying to get the links back in the axle bracket, repeat was the biggest pita to do by yourself. In hindsight it was a two man job, when a single left hand thread is all that is needed to solve this issue.
Leave the RH/RH lowers. It's not a big deal, the whole axle doesn't try to twist out from underneath you and a simple roll of the tire will get you back in the axle bracket. The single upper is a whole other story.
I should of knew the Clayton fanboys would be coming out..
Old January 10th, 2013, 09:37
NAXJA Member #180
What you did was no diffrerent than installing/adjusting upper control arms on any aftermarket setup. Its always hard getting that first one in. I think the alignment rack was your problem. If you have to do it again, take the weight completely off the front axle. Just allow the tires to touch slightly. Put a jack under the yoke and adjust as needed. You can make small tweaks by putting a tire iron through the knuckle too. This always seems to work well for me.
Rate This Thread:
Clayton Off Road Mfg. - End of the Year Holiday SALE 5-15% Off All Clayton Products!! Clayton Off Road Vendor's Specials 4 December 29th, 2010 21:17
Clayton Off-road 99XJSp Modified Tech Discussion 2 April 3rd, 2010 07:29
Clayton Off Road Mfg. - New trackbar bushing Upgrade Clayton Off Road Vendor Advertisements 0 March 24th, 2010 08:09
Clayton Off Road Mfg. - 7 Day Thanksgiving Day Sale 5-15% Off Everything Clayton Off Road Vendor's Specials 6 November 28th, 2009 14:56
Clayton Off Road Mfg. - 7 Day Thanksgiving Day Sale 5-15% Off Everything Clayton Off Road Vendor Advertisements 3 November 24th, 2009 15:53
