Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old March 20th, 2004, 17:49
Goatman's Avatar
Goatman Goatman is offline
Talking Will my stroker beat CRASH's stroker?
I gotta be able to beat CRASH back to camp after running trails, and we're both getting strokers in this spring, so just for fun, I wonder what opinions are on whether mine or his will have the advantage. He'll have to put his specs up here, but here's mine.
Renix motor, 258 crank and rods, stock 4.0L 0.30 over pistons, stock head, Crane 753901 cam, 58mm bored Renix TB, Clifford header, 2.5" exhaust and Dynaflow muffler with no cat, 24lb injectors with 49psi FPR. The compression ratio is high (10 to 1) so it'll run premium gas. Good valve job, new springs, etc., but otherwise no special head work or machining.
CRASH, what will you end up with?
I'm wondering if I should go ahead and do some head work, port matching, polishing, etc., or will I have enough to keep with him without all the time and labor to do head work. Superior driving and suspension design will give me the edge, as long as my motor is as good or better than his.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old March 20th, 2004, 19:19
XJZ XJZ is offline
Re: Will my stroker beat CRASH's stroker?
...now this will be fun.....
Old March 20th, 2004, 21:38
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Don't rule out all the high-tech URF mods that he'll have up his sleeve.......
Speak the Truth-Question with Boldness-Speak without fear.
Old March 20th, 2004, 22:35
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Sorry to burst your bubble Goatman but when I've finished my stroker it'll blow away both yours and Crash's.
Specs will be '00 4.0 block bored +0.020, 258 crank & rods, Sealed Power 677P pistons, Crane 753905 cam, Mopar Performance springs/retainers, 9.5:1 CR, Ported '92 HO head, 62mm TB with 62mm TB spacer, Borla header, 2.5" Magnaflow exhaust, Ford 24lb injectors, MAP adjuster, JET Stage 2, 180* t'stat, Flowkooler water pump, dual electric fans.
Also have polyurethane front/rear swaybar bushings and HD gas shocks to take care of the twisties.
______________________________________________
- 1992 4.0 XJ Laredo UpCountry with modifications - 172k miles - AX15, NP231, D35c, D30
Estimated 240hp@5250rpm/280lbft@3500-4000rpm, 1/4=14.98@93.1, race weight 3465lb
- Future mods -
4.6L stroker (under construction)
- Websites -
Jeep 4.0 performance, 4.6L stroker build-up
- Tech Webpages -
CTS resistor trick, Dual electric fans, IAT sensor relocation, Intake manifold heatshield, MAP adjuster, Oil temp. gauge install
- Info Pages -
Automotive formulae, Jeep 4.0 cam specs, Jeep engine dyno graphs
Old March 20th, 2004, 23:01
Goatman's Avatar
Well, Dr D, mine is built for hauling ass through the desert.......after finishing a good, hard, rockcrawling trail.
I figure I better get a stroker, 'cause right now I run flat out, and the 'ole 180k '88 Renix, with only 10psi in the tires, doesn't get me much above 55-60 mph unless I'm going slightly downhill. I have to watch my back because the guys, like Jes, Hinkley, and FlexyXJ with the newer HO motors, blow right past me when the road smooths out. Farmer Matt, with his Clifford stroker, can take me anytime as long as he watches ahead for the big whoops....
I'm getting my bumpstops dialed in (the rears are working great), and I have some Sway-A-Way nitrogen charged, remote reservoir shocks coming by the end of Mar, so when the stroker goes in I'm anxious to see what it'll do.
I don't get to have a Jet chip, and I'm not going to mess with a nicely ported HO head, with a little larger TB, but it still should be a significant improvement over what I have now. With all of my heavy rockcrawling gear...big axles, bumpers, roll cage, etc, plus all the tools and parts that I carry.....I'm probably almost 1000 lbs heavier than you are. But, I'd still take you on if we're on a dirt road. Oh, and BTW, be careful with that D35 rear end. A good friend did a real nice 4.7L stroker, built by his neighbor who builds race car motors, and he blew out his D35 ring and pinion on the street less than two weeks after the stroker went in.
Hey, where's CRASH?
Old March 20th, 2004, 23:33
Loose_Nuts_Enterprises's Avatar
Loose_Nuts_Enterprises Loose_Nuts_Enterprises is offline
Richard, I think you should leave the muffler off to retain that Jaws fishing boat sound (jaws music...)
Are you gonna get that welder fixed, or start carrying 3 batteries around? Better add that weight to your estimate, lol. BTW, the motor sounds killer.
Dan
Old March 21st, 2004, 01:11
Wiley Coyote's Avatar
Wiley Coyote Wiley Coyote is offline
Dr Dyno, Iím trying not to sound dumb here, but why are you using a í92 head instead of a newer head and intake? I thought that the í96 and up heads and intakes were supposed to be better. On another note; does the JET Stage 2 chip give you any hp gains above and beyond the adjustable MAP sensor? I built and installed a copy of your adjustable MAP sensor and Iím trying to figure out if itís worth it to buy the chip too.
Old March 21st, 2004, 04:19
Dr. Dyno's Avatar
I have my original '92 head as a spare so that's why I'm using it. The '91-'95 heads are the best 4.0 heads for performance anyway. I'd like to get my hands on a '99+ intake manifold but the only one I could find in a junkyard over here was being sold for nearly $200. I wasn't going to pay that much so I rejected it. There's one being sold on e-bay right now and I hope I can win the bid.
I've had my JET Stage 2 for 6-1/2 years so I've decided to keep it. It hardly makes any difference except at higher rpm.
I'm aware that the D35 might be a weak link in my drivetrain when I get my stroker installed. I'm going to be careful with it initially (I'll be breaking in the engine anyway) and not do any hard launches until I know what the limits are. I have 225/70R15 tires that are only 27.4" diameter so I think the lighter wheels will be less stressful on the rear axle and reduce the risk of breaking it.
Old March 21st, 2004, 07:42
rav's Avatar
rav rav is offline
Hey, where's CRASH?
having ported my 88 head, i can tell you that there is a lot of metal you can shave off by just doing a gasket match of the ports, you wont be surprsied why the newer ones are "HO" as the ports are so small, so do a good port job alongwith a 3 angle valve job and you are good to go.
Ravi
Old March 21st, 2004, 12:45
Goatman's Avatar
Yeah, my friend was running 33's with 4.56 gears......you're much better off with the smaller tires as far as reliability goes.
Old March 21st, 2004, 18:07
rsalemi rsalemi is offline
Richard - Don't know if you will beat him; but I do know it will go 100 MPH easy!! You will NOT be able to go flat out - unless you go to Bonneville!
Old March 21st, 2004, 20:31
strokedwoody strokedwoody is offline
Nothing matters if it won't smoke down 38 swampers from a stand still. Seriously...I built mine cause I blew the motor up and it was much more expensive than stock rebuild. I used every part in it new other than the block and the head and still only spend a grand or so(owning a shop did help keep the cost down).Used a renix motor, lightened rods, .30 pistons nothing fancy just cast, crane cam , little port work etc.. but the joy is hooking it up to a 9" with 5.38 gears, a detriot and melting down a set of 38's from the light and dont even get me started on the donut fun....
Old March 21st, 2004, 21:16
AndyS AndyS is offline
I'm wondering why you all are using the short, heavier 258 rods with your strokers? A longer will give a better rod ratio, better rod angle and more dwell time at TDC. I understand the cost aspect, but if you're gonna go to the trouble of building a stroker, wh ynot maximize your potential? Plus, you get a full range of compression ratio options...no need to use overpriced 91+ octane gas...
Does anyone have any information regarding emissions readings after building a stroker (long or short rod)? I'm contemplating a stroker for my '94 HO, but I live in a state where I have to pass an IM240 "dyno" style emissions test. I don't want to build a nice motor for my daily driver, only to flunk the emissions test. Anyone have any first hand experience in this department? Thanks!
Andy
Old March 21st, 2004, 23:10
Dr. Dyno's Avatar
Originally Posted by AndyS
I'm wondering why you all are using the short, heavier 258 rods with your strokers? A longer will give a better rod ratio, better rod angle and more dwell time at TDC. I understand the cost aspect, but if you're gonna go to the trouble of building a stroker, why not maximize your potential?
While the benefits of longer rods are well known, you have to combine them with shorter pistons to build a stroker. Since the only ones available are custom forged items that cost $500+, many will baulk at the idea of spending that much on pistons alone. The other disadvantage of these pistons is their tendency to slap in the bores when cold and the shorter skirt causes them to rock, thus making the engine sound like a diesel. This leads to another possible issue of long term reliability. If the pistons are slapping around in the bores so much, there's a greater chance of accelerated cylinder wall wear and damage to the piston skirts.
Old March 22nd, 2004, 07:37
CRASH's Avatar
CRASH CRASH is offline
Here I am!
I am using Eagle 258 rods, venolia forged pistons, 9.2 to 1 compression, Isky 133125/26 hybrid cam, 26 lb injectors, AEM AFPR, Pacesetter header, 2.5" mandrel bent exhaust, 58 mm TB.
Oh, and a nice little blue bottle for those quick passes.
CRASH
Rate This Thread:
Ordering stroker stuff... AndyS Modified Tech Discussion 12 February 1st, 2006 21:09
budget stroker robert stalberger Modified Tech Discussion 12 March 20th, 2004 09:43
stroker goes awesome!! thanks guys.. alwayzAMC Modified Tech Discussion 2 March 17th, 2004 19:29
whoo hooo! Stroker time! afjeep2082 Modified Tech Discussion 44 March 5th, 2004 17:14
Stroker group HossHoffer Jeep Street and Performance 2 August 30th, 2003 16:35
