Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > Cherokee Crawl 2015
Cherokee Crawl 2015 July 3rd - 4th, 2015 - Black Mountain Off Road Adventure Area - Harlan KY Event sponsored by H.D. OFFROAD ENGINEERING
Old June 29th, 2015, 17:16
BRIANHO13's Avatar
BRIANHO13 BRIANHO13 is offline
<- Yum Chocolate
Tools
Who's got what?
Should I bring the mig?
Old June 29th, 2015, 17:26
043500 043500 is offline
Re: Tools
I have an angle grinder and fairly heavy duty drill and a good 3/4" bit (smaller bits as well).
Also vast assortment of small tools including snap ring pliers and 10b/44 hub tool and 60/14b hub tool ( I think the 60 and 14 use the same one anyway).
Have a 4 ton comealong too.
1987 MJ renix 4.0/AW4, D300, 60/14B welded 5.13's and 37's.
1993 XJ 2 dr, 5" lift and 32's
2003 dodge ram 3500 cummins
  #3
Old June 29th, 2015, 17:45
GoSlowGetStuck's Avatar
GoSlowGetStuck GoSlowGetStuck is offline
Tools
I am bringing a decent floor jack and a pair of 6 ton jack stands to install coils in the campground if anyone needs something safer than a hi lift.
Sockets to do a D30 hub/shaft.
Brake line flaring tool and some line.
Ball joint press, tap and die set.
Trying to bring the more specialized stuff that not everyone carries.
I am also considering bringing my manifold gauge set and vac pump to do A/C, if you are interested let me know. No refrigerant though, an XJ needs two 12oz cans.
Brad - Midwest Chapter Treasurer
97 XJ build thread
  #4
Old June 29th, 2015, 18:28
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
Re: Tools
I'll have the welder and the seanr campground adapter.
  #5
Old June 29th, 2015, 19:24
89eliminator 89eliminator is offline
Re: Tools
i will have a grinder and sawzall. never know when an XJ needs a roof cut
  #6
Old June 29th, 2015, 19:49
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Re: Tools
I've got my mig and floor jack and jack stands. Sawzall and angle grinder which Brian cannot play with. OBA and assorted tools. I have a bunch of spare parts too. D30 2wd stub, 231 tail shaft. Coil, distributor, assorted hoses and belts. Tire groover ....
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
  #7
Old June 29th, 2015, 20:46
Buzzstrike's Avatar
Buzzstrike Buzzstrike is offline
Re: Tools
WHY does it sound like that this has been done before.
Endeavor to persevere. Every day.
  #8
Old June 30th, 2015, 22:40
89xjgrey's Avatar
89xjgrey 89xjgrey is offline
Re: Tools
I'll be bringing my Snap-on Verus pro diagnostic scanner...should the need arise...
Rate This Thread:
Tools! dlarrivee OEM Tech Discussion 14 December 24th, 2007 04:56
air tools? mike harris Modified Tech Discussion 2 September 1st, 2004 14:15
