Old December 14th, 2019, 17:36
Borgli Borgli is offline
Holy sii, did that just happen! Buddy's 4.8 stroker
Hey guys,
Me and a buddy were working on his stroker build today, we got the crank and 3 pistons in no problem. Then it all went sideways. One of the oil rings caught on the wall before entering the cylinder and made a gash all the way don't. (that's our theory on what happened anyways)
Is this salvageable or does he need a new block?
Old December 14th, 2019, 17:37
Re: Holy sii, did that just happen! Buddy's 4.8 stroker
https://www.flickr.com/photos/186020...posted-public/
Old December 14th, 2019, 17:46
RCP Phx RCP Phx is offline
If it's truly a 4.8 (.080" over) then I would say yes to another block, never seen one though!
Old December 14th, 2019, 18:18
BTW, do you have a pic of the piston? It can't look good!
Old December 14th, 2019, 18:20
ehall's Avatar
ehall ehall is offline
damn!
my '91 beater rebuild
Old December 14th, 2019, 18:22
No marks on the piston. Looks the same as before going in. The ring is only slightly be too. I don't understand how it can have massed it up that bad
Old December 14th, 2019, 19:02
Who the hell did the block in the first place? That machining looks horrible.
Old December 15th, 2019, 03:37
I think that's part image quality, part flash rust. Looked a lot better when we picked it up a year ago.
Went back out to check it with a clearer less pissed off mindset. It's not as bad as we first feared(still really bad). On the left side of it theres a ride that can be felt easily, but the markings on the right are smooth, no noticable difference there compared to the rest of the bore. I'm guessing the crosshatching is gone though.
We'll pull everything off it and take it to a shop.
I'll update when we hear back from them, sometime after Christmas.
Old December 15th, 2019, 12:16
old_man's Avatar
old_man old_man is offline
At .080 over, I would have the cylinders sonic tested for thickness.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old December 15th, 2019, 17:50
It's bored 100 over at 3.975in. It's a meaty renix block, plenty left on the walls. We got it stripped back down today.
Anyone know if sealed power sells oil control rings? Kind of a waste to buy a new 60$ set.
Old December 15th, 2019, 18:30
It's kind of a waste to assemble this motor!
Old December 15th, 2019, 18:54
Anak's Avatar
Anak Anak is offline
Stranger
I have purchased a single piston's worth of rings before. That is probably what you are looking at doing.
FWIW, that was what made me swear off band type ring compressors.
A good machine shop should be able to determine if you have a real problem or if a couple passes with a finish hone will get you back in business.
Baby it's cold outside.
Old December 15th, 2019, 21:57
Old December 16th, 2019, 06:46
It just doesn't sound like a healthy build. Is this the motor with the Hesco head?
Old December 16th, 2019, 07:12
Evan03 Evan03 is offline
I'd probly run a hone through it real quick along with a new set if rings.
It most likely will be fine.
It's just jeep motor a good one to learn on. Dont frett the small stuff. Bolt it together and hit the trails.
need help for a buddy jeepfreak1020 Colorado Chapter 2 April 21st, 2011 17:21
Test Results from Stroker Overheat (Overheated the Stroker Badly- Part DUEX) NHxj4x4 OEM Tech Discussion 36 January 24th, 2010 18:54
Articulation? holy holy! It was a CJ. "Chainlink extreme 4x4" clean96XJ Non-Tech / Off Topic 6 January 7th, 2010 12:57
Finally took apart my Stroker (Stroker Overheated Badly) Part Trois NHxj4x4 OEM Tech Discussion 7 April 15th, 2008 11:45
Buddy looking to buy an XJ. ChuckD Sierra Chapter 3 June 18th, 2007 15:11
