KRAKER
- where blank stares are normal
Updates will be posted as it gets closer.
Thread can be found here. http://www.naxja.org/forum/forumdisplay.php?f=266
This years event basecamp will be located at the Black Canyon City KOA...
When you make your reservation CAll and be sure to mention you are with the group for a 15% discount on your reservation
More information as fas a location and ammenities can be found here.
http://koa.com/campgrounds/black-canyon/
In order to participate on this (and any other) event you must follow the below:
Minimum Equipment Requirements
1: Visibly charged fire extinguisher (BC or ABC type)
2: First Aid Kit
3: Adequate spare tire, jack, and lug wrench*.
4: Safety belts for driver and all passengers.
5: Adequate tow points. Must be of OEM or greater integrity (no three bolt cheap brackets), d-rings, shackels, etc are all good as long as the hook or bumper brackets meet or exceed the OEM kit. Welded tow hooks are never allowed.
6: Snatch strap without metal hooks.
7: Battery must be properly secured.
*Notes*
Rule 3 may be waived at trail leaders discretion.
Safety Rules
Driving under the influence of drugs or alcohol is not permitted.
Safety belt use is mandatory.
Pets should be well-behaved or secured.
Do not exceed the maximum speed limit on all roads, public or private.
2: First Aid Kit
*Notes*
Safety Rules
